Meguiar's New 3 Inch Professional Headlight & Spot Repair Kit
Look what Max dropped off in the Show Car Garage Studio for us to test out...
Meguiars Professional Headlight & Spot Repair Kit
Kit includes:
1 Pneumatic Mini DA Sander
1 Pneumatic Mini Rotary Polisher
50 S3320 Unigrit 320 Grit Sanding Discs
50 S3500 Unigrit 500 Grit Sanding Discs
50 S3800 Unigrit 800 Grit Sanding Discs
15 S3F1000 Unigrit 1000 Grit Finishing Discs
25 S31500 Unigrit 1500 Grit Sanding Discs
15 S3F3000 Unigrit 3000 Grit Finishing Discs
1 S3FIS Unigrit Foam Interface
2 W4003 3” “Easy Buff” Knitted Wool Pads
2 W7204 4” Soft Buff Foam Cutting Pads
2 W8204 4” Soft Buff Foam Polishing Pads
2 W9204 4’ Soft Buff Foam Finishing Pads
2 S3BP 3” Professional Backing Pads and Adaptor Kits
1 S3HP 3” Professional Hand Pad - 1 ea
1 W63 3” Professional Rotary Backing Plate
1 T18MM Professional Masking Tape .75in
1 8 oz. Meguiars 105 Ultra-Cut Compound
1 8 oz. Meguiars 205 Ultra Finishing Polish
1 Meguiar’s Black Canvas Bag
1 Professional Headlight and Spot Repair Chart
This is a very complete kit with everything you need to refinish headlights that have deteriorated to the point where only sanding can save them and/or for doing spot sanding or spot damp-sanding to remove isolated defects out of fresh paint or factory paint.
http://www.autogeekonline.net/galler...air001_jpg.JPG
After opening the box you'll find a soft case that hold everything inside with extra pockets on the outside for other tools or accessories...
http://www.autogeekonline.net/galler...air002_jpg.JPG
http://www.autogeekonline.net/galler...air003_jpg.JPG
Here I've spread everything out to show the complete selection of products found in the kit...
http://www.autogeekonline.net/galler...air004_jpg.JPG
There are two backing plates with 4 different adapters which enables you to attach the backing plate to just about every known thread size used for small air tools.
http://www.autogeekonline.net/galler...air005_jpg.JPG
The kit comes with 2 Chicago Pneumatic Air Tools, one is a Mini Dual Action Sander and the other is a Mini Rotary Polisher and both are clearly marked on the outside housing.
http://www.autogeekonline.net/galler...air006_jpg.JPG
The Mini Dual Action Sander
After determining the correct adapter for sander you rotate the black hub until you see a hole align with the cutout on the exterior casing.
http://www.autogeekonline.net/galler...air007_jpg.JPG
http://www.autogeekonline.net/galler...air008_jpg.JPG
http://www.autogeekonline.net/galler...air009_jpg.JPG
The kit comes with a wrench and a dowel type rod with a handle.
http://www.autogeekonline.net/galler...air010_jpg.JPG
Place the steel shaft of the dowel through the cutout to pin the rotating assembly against the housing, this will enable you to attach the backing plate and tighten the backing plate to the rotating assembly.
http://www.autogeekonline.net/galler...air011_jpg.JPG
http://www.autogeekonline.net/galler...air012_jpg.JPG
http://www.autogeekonline.net/galler...air013_jpg.JPG
http://www.autogeekonline.net/galler...air014_jpg.JPG
Now you're ready to attach the foam interface pad...
http://www.autogeekonline.net/galler...air015_jpg.JPG
The Meguiar's 3 inch Spot Repair Kit uses hook and loop style interface, so align the loop side of the interface pad, (the side with the "M" on it), and attach to the hook side of the face of the backing plate and do your best to align so it's centered or true.
http://www.autogeekonline.net/galler...air016_jpg.JPG
Next select the grade of Unigrit Disc you want to use and align it to the interface and press on firmly.
http://www.autogeekonline.net/galler...air017_jpg.JPG
Here's the sander with interface and Unigrit sanding disc attached...
http://www.autogeekonline.net/galler...air018_jpg.JPG
http://www.autogeekonline.net/galler...air019_jpg.JPG
http://www.autogeekonline.net/galler...air020_jpg.JPG
You're ready to go to work...
http://www.autogeekonline.net/galler...tRepair034.jpg
Re: Meguiars Professional Headlight & Spot Repair Kit
Continued...
The Mini Rotary Polisher
The rotary polisher comes with a wrench to hold the spindle assembly.
http://www.autogeekonline.net/galler...air021_jpg.JPG
After selecting the appropriate adapter for your tool, affix it to the backing plate first making sure the washer is between the backing plate and the adapter and then thread into the spindle assembly and tighten down a 1/4 turn after snug.
http://www.autogeekonline.net/galler...air022_jpg.JPG
http://www.autogeekonline.net/galler...air023_jpg.JPG
http://www.autogeekonline.net/galler...air024_jpg.JPG
Select the right buffing pad for the task at hand and then align the backing plate to the hook and loop interface and press firmly.
http://www.autogeekonline.net/galler...air025_jpg.JPG
http://www.autogeekonline.net/galler...air026_jpg.JPG
You're ready to start polishing...
http://www.autogeekonline.net/galler...air027_jpg.JPG
The kit also comes with a hand backing pad for working by hand...
http://www.autogeekonline.net/galler...air028_jpg.JPG
And also a 3" rotary backing plate...
http://www.autogeekonline.net/galler...air029_jpg.JPG
There are two 10 ounce bottles of M105 and M205...
http://www.autogeekonline.net/galler...air030_jpg.JPG
Everything you need for professional results...
http://www.autogeekonline.net/galler...air032_jpg.JPG
A fold out poster is included that shows step-by-step prodedures...
http://www.autogeekonline.net/galler...air033_jpg.JPG
On the Autogeek.net website
See also...
Meguiar's 6" Unigrit Sanding and Finishing Discs
:xyxthumbs:
Re: Meguiar's New 3 Inch Professional Headlight & Spot Repair Kit
What compressor is required to run these tools? I could not find any specs on either Meguiar's or Chicago Pneumatic's web sites.
I notice they do not include a sealant, do they recommend one?
I asked the Meguiar's rep (At Detailfest last year) how much air the tools used. I don't remember his exact answer but it was a lot like 14 cfm at 90 psi.
I thought a while back they had switched tools to composite body ones?
Quote:
Originally Posted by
Jokeman
They were supposed to have done that, yes... but curiously they have recently released the Chicago Pneumatic (CP) DA and Rotary as stand-alone "replacements" packaged with an S3BP under the part numbers those new composite tools were supposed to have had (G-3ROT and G-3DA). I see that AG carries the DA version; another vendor has both:
Meguiars Headlight Kit Replacement Pneumatic 3 inch DA Air Tool, air sander
