Quote:
Originally Posted by Slava Would it be beneficiary to use 2K, 2.5K and 3K on the same spot and then remove scratches? |
That's what I did.
The idea being to reduce the depth of the scratches to a minimum to make it easier for a tool with a free rotating spindle assembly to remove them.
I could have finished sanded using the Abralon #4000 grit discs but I wanted to stick with papers the average enthusiast has access to.
The GG ROP removed them without flinching on this paint system with the products shown, a person could remove them even more easily with a more aggressive compound.
I purposefully used non-aggressive products just for demonstration purposes.
Of course in the real world if I were sanding I would use a rotary buffer with a wool pad to remove my sanding marks because it's the fastest and most efficient way to remove a lot of paint quickly.
