SELF BANNED
Re: wet sanded 68 camaro
Originally Posted by nrengle
Mike great info! You would probably know the answer to what I mentioned earlier. How well does body filler (IE Bondo) play with our rotaries and to a lesser extent, DA's? Can it be pretty flaky to work with, as sensitive as plastic with a flex agent in it, or is it pretty rock solid like working on actual body panel (never mind soft/hard paint)?
You will not even notice you are polishing over bondo, the only time you will notice it if it is put on thick.
Thank you Mike for taking the time to give a great explanation on wet sanding! That helped me out big time coming up with questions for the guys at the body shop. I looked at the camaro tonight, it has been sanded with 2000 grit for sure. The painter said he sprayed 3 very heavy coats of clear on as well. I'm no body man but it is very obvious looking at the car that the clear is thick on this one! I'm getting the trunk lid on monday but won't get the rest of the car until its fully assembled in a week or so. Gives me time to do more research!
By corky5678 in forum Wet-Sanding, Cutting & Buffing
Last Post: 10-30-2014, 03:10 AM
By xof in forum Wet-Sanding, Cutting & Buffing
Last Post: 06-11-2013, 10:46 AM
By robollama in forum Auto Detailing 101
Last Post: 09-13-2011, 08:13 PM
By Thejoyofdriving in forum Auto Detailing 101
Last Post: 08-01-2007, 08:46 PM
By nbk13nw in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 05-04-2006, 11:23 PM
25 | 26 | 27 | 28 | 29 |
