Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. #21
    Super Member Corey@OptimalDetailing's Avatar
    Jan 2013
    Norman, Ok
    565
    Re: waffle weave question:prewetting
    Quote Originally Posted by BF4Noob73 View Post
    Is the purpose of the waffle weave towel to soak up ALL or MOST of the water? I have the chemical guys gray waffle weave 25x36" towel and my understand was it's suppose to completely DRY in one swipe. I have to ring it out after each panel, but there is still water left behind. So I dunno *shrug*
    If you are starting out with a dry WW towel, it will not soak up all of the water on the first swipe, plain and simple. If you have 'that much' water standing on horizontal panels, try to sheet the water off before starting your towel drying process.
    I, personally, utilize a dampened WW towel for drying. Typically I will give it quite a few sprays of a drying aid, then spritz it once per panel with the same drying aid. Adds protection and makes drying a breeze.
  2. #22
    Nov 2015
    Los Angeles, California
    13,765
    Quote Originally Posted by Corey@OptimalDetailing View Post
    I totally disagree.^
    I have the same exact waffle weave that he's talking about [CG Gray Matter 25x36] and it works great starting out dry. The only way I could imagine his situation happening is if he's starting out with a wet towel.
    That towel is 30/70 and takes quite a bit of water to finally load up. And when it does it becomes heavy and doesn't ring out really well, nor does it dry really well once it's become totally wet.
  3. #23
    Jan 2013
    Norman, Ok
    565
    I, too, am speaking of the same exact towel. Opinions are different, just stating the method I use as it works for me.
    In regards to dry vs wet MF towels drying better, that's a different argument in itself.
  1. Which waffle weave is this?
    By SANTA3013 in forum Auto Detailing Tools and Accessories
    Last Post: 07-13-2014, 10:53 PM
  2. Drying with waffle weave
    By frankprozzoly in forum Auto Detailing 101
    Last Post: 06-01-2014, 04:48 AM
  3. Waffle Weave ?
    By EddieF in forum Hot topics & Frequently Asked Questions
    Last Post: 04-01-2013, 12:19 PM
  4. The Ultimate Guzzler Waffle Weave question
    By PurpleHaze in forum Auto Detailing Tools and Accessories
    Last Post: 06-28-2010, 06:26 PM
  5. How do you dry your Waffle Weave after using them?
    By Downgear in forum Auto Detailing 101
    Last Post: 03-31-2008, 10:15 AM
