Go Back   Auto Geek Online Auto Detailing Forum > Detailer's Library > Tricks, Tips and Techniques
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 05-10-2012, 10:52 AM   #1
Director of Training
Mike.Phillips@Autogeek's Avatar
Mike's Glass Cleaning Tips
When cleaning glass or anything, you are removing "something" off the glass. On the inside this would be Vinyl Fog and/or Smoker's Film.
Chances are good you're also cleaning someone else's attempt to clean glass and removing their streaks and smears plus whatever chemical they used to try to clean the glass.
Depending on who's riding around in the vehicle you could also be removing fingerprints and even footprints from passengers sitting in the front seat and stretching their legs out onto the dash. Kids are notorious for touching the inside of glass with their fingers and hands and that means residues from whatever was in their hands including ketchup and mustard from their McHappy Hamburger, grease from their French Fries or Chicken McNuggets and anything else they're playing with in the back of the car.
So here's my tip on cleaning glass...
Anytime you're mechanically removing any type of film, oils or any other substances off the glass, they are being deposited onto your wiping cloth. Correct?
That means you should no longer use that wiping cloth on any other glass surface because all you'll be doing is transferring the substance you removed to a new section of glass.
Have plenty of glass cleaning towels
Plenty of Towels
The most important thing you can do to avoid streaks and smears when cleaning glass is to use plenty of clean wiping cloths and after making the initial wipe over a window or a section of a window, either turn or fold to a fresh clean side or switch to a clean, dry, unused wiping cloth to continue.
It doesn't take much to leave a smear on glass so your job is once you remove the majority of whatever was on the glass to start with to get that wiping cloth out of the equation and switch to a new, clean wiping cloth for your final wipe. Then after using the secondary or even third wiping cloth on a single window, set it aside and start on the next window with another clean, dry wiping cloth.
Glass Cleaners
Most glass cleaners work really well, especially if the name on the label has a good reputation to start with.
Glass Towels
Most quality microfiber towels and dedicated glass wiping towels also work really well.
Cross-contamination the true culprit
The culprit is re-introducing whatever it is you removed off the glass back onto the glass.
Glass Master Pro
I like using Glass Master Pro for front and back windows for the "Final Wipe" not for the first or even second wipe.
Tips and Techniques - 3 Wipes for streak-free glass
1st Wipe
The first wipe is to remove the majority of any Vinyl Fog, Smokers Film, Fingerprints, Smudges and Smears. After you make the first wipe, take the towel now holding any residues previously on the glass and place it in your laundry bag or bin as it is no longer useful for cleaning glass.
2nd Wipe
The second wipe is to further remove any trace residues left behind by the first wipe, these will show up as smears on the glass. Use a clean, dry wiping cloth together with a quality glass cleaner. After this wipe the glass should be about 90% clear and streak-free or better.
3rd Wipe
For the third and final wipe, switch to the Glass Master Pro. The Glass Master Pro come with
After making your initial wipes for the inside of the windshield using a clean, dry glass cleaning towel, switch to a clean dry towel for a second wipe. After your initial wipe and follow-up wipe using clean, dry un-contaminated cleaning towels you're now ready to use the Glass Master Pro for the "Final Wipe".
Mist a little glass cleaner onto a clean, microfiber bonnet, this should be a very light amount of glass cleaner.
Then make your final wipe for the inside of the front windshield and rear window, which are normally the hardest windows to clean.
Check it out on Autogeek.net
Diamondite® Perfect Vision Glass Cleaner Aerosol
Waffle Weave Microfiber Glass Towel
__________________
How-To Articles
Live Broadcast Videos & Pictures
Facebook
Mike.Phillips@Autogeek is offline
Old 05-10-2012, 01:50 PM   #2
dwlinc23's Avatar
Re: Mike's Glass Cleaning Tips
As always very useful info!
I do at least 3 wipes as well.
__________________
If it isn't detailed, it isn't clean.
www.detailsbydale.com
http://www.facebook.com/pages/Detail...47374478729200
dwlinc23 is offline
Old 05-10-2012, 03:33 PM   #3
rider9195's Avatar
Awesome tips Mike! I usually just stick with two cleanings as it works for me. But I will try a third as well!
__________________
Ryan 2006 Volvo S60 R
rider9195 is online now
Old 05-29-2012, 03:14 PM   #4
Quote:
When it comes to cleaning glass, this is really an area where more is better just to prevent cross-contamination and residue-transfer.
__________________
How-To Articles
Facebook
Old 05-29-2012, 09:16 PM   #5
Member
Millennium's Avatar
Very good points. I finally found a glass cleaner that works great for me. I spray the cleaner unto the window, spread with a microfiber towel and buff with a surgical blue "paper" towel. After I do all the windows, I finish by buffing one last time.
__________________
Millennium Auto Care
www.millenniumdetailing.com
https://twitter.com/MillenniumAuto
Atlanta, GA
Millennium is offline
Old 05-29-2012, 10:20 PM   #6
BrightonRT's Avatar
Just tried these tips on my daily driver windshield, that helped get that last bit of streaking. Thanks!
BrightonRT is offline
Old 05-29-2012, 10:52 PM   #7
Hmm..so the third and final wipe is wet as well? I guess if it's already very clean it doesn't matter.
I usually wipe using only a dry towel on the final wipe thinking this will eliminate any possible smears from the previous wet wipes. I guess this is also like post #5 that buffs with the dry blue towels as the last step.
bigez is offline
Old 05-30-2012, 12:12 AM   #8
pickles's Avatar
With windows I usually use a damp towel(out of the washing machine) with the cleaner and then a dry one right after to get the streaks.Damp microfiber for me works really well so I'll throw my cleaning towels in the washer while washing the outside of the car.I go in opposite directions(horozontal vs vertical) when I use the dry towel to clear up the streaks.
No dogs,no kids and no smoking so my windows don't really get too dirty anyway.Also because they get cleaned once a week or so.
pickles is offline
Old 05-30-2012, 03:30 AM   #9
jpegs13's Avatar
I have to try this. Glass has always been the most frustrating area for me. Thanks for the tip!
__________________
John
Mean people suck
jpegs13 is offline
Old 05-30-2012, 07:13 AM   #10
Quote:
Being clean is very important or you simply back to cross-contamination.
Here's my tip sliced out of the original article, note I tend to choose each and every word I post to a public forum very carefully being a Veteran of the NXT vs Zaino wars back in 2004. It's my writing style, I call it defensive writing, you can be sure that when I make a post it's battle proof and I can defend it or I would never post it.
Quote:
And just to note, I probably took 10 to 12 actual pictures before I could get one that shows "spray" coming out of the nozzle. This is for a "visual effect" because to simply mist a little glass cleaner onto the microfiber bonnet on the Glass Cleaner could not and would not make a very good visual picture.
Just to clarify because I agree with you in that for the final wipe you should be working with a clean towel on almost perfectly clean glass. So either a LITTLE mist of glass cleaner or if it works for you, a dry towel. For me I like the little mist of product.
__________________
How-To Articles
Facebook
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Glass Cleaning 101 Matt How to Articles 39 06-09-2012 09:52 AM
Ugh...Inside Windshield is the DEVIL!!!! Bamaboy007 Auto Detailing 101 27 04-16-2012 07:44 AM
Autogeek Commercial - How To Remove Water Spots with Diamondite Glass Cleaning System Mike.Phillips@Autogeek Two Guy's Garage & My Classic Car TV Shows 1 05-16-2011 04:10 PM
Are All Microfiber Towels the same??? mammoth713 Auto Detailing University 14 09-07-2009 08:51 AM
Polishing Glass, how to? Whitethunder46 Auto Detailing 101 5 12-16-2006 08:58 AM
» May 2013
» Car Care Brands
