Go Back   Auto Geek Online Auto Detailing Forum > Detailer's Library > Tricks, Tips and Techniques
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 04-18-2012, 11:39 AM   #1
Director of Training
Mike.Phillips@Autogeek's Avatar
Tip: Use the rubber nut to protect threads and prevent loss of the compression washer
Tip: Rubber Nut to protect threads and safeguard compression washer
When you purchase a backing plate for your DA Polisher it comes with a Compression Washer held in place with a Rubber Nut.
Here's a tip, when using your backing plate keep the rubber nut in a safe place for use later.
The Rubber Nut does two things,
  • Protects the threads on the backing plate when the backing plate is not in use.
  • Holds the Compression Washer in place so it does not get lost when the backing plate is not in use.
Backing Plates on Autogeek.net
Lake Country 5" DA Backing Plate
Lake Country 3" DA Backing Plate
Lake Country 3.5 " DA Backing Plate
Lake Country 6" DA Backing Plate
Meguiars W67DA G110 DA Polisher 5 inch Backing Plate
The Black Dual Action 5 Inch HD Backing Plate
Dual Action 6 Inch HD Backing Plate
Meguiars W68DA Dual Action Backing Plate
3M Hook-It 5 Inch Dual Action Backing Plate - 5775
3M Hook-It 6 Inch Dual Action Backing Plate - 5776
Related articles...
The Compression Washer
Don't use your polisher without it!
5 inch Backing Plates on Meguiar's, Griot's and Porter Cable DA Polishers
__________________
How-To Articles
Live Broadcast Videos & Pictures
Facebook
Mike.Phillips@Autogeek is offline
Old 04-19-2012, 07:59 AM   #2
Re: Tip: Use the rubber nut to protect threads and prevent loss of the compression washer
If I may Mike...
IF you do loose the rubber topper, there are soft plastic caps available, again, at you local hardware store.
These little plastic caps are used to cap off cut metal rods and such.
Bill
BillE is offline
Old 04-19-2012, 09:05 AM   #3
Quote:
Originally Posted by BillE View Post
If I may Mike...
Bill
Great point.
A person could also simply wrap a little painter's tape around the threads to protect the threads and to keep the compression washer from falling off and getting lost.
__________________
How-To Articles
Facebook
Old 09-14-2012, 03:16 PM   #4
You could also use a rubber cap used for vaccum port blocking off. They can be had at any auto parts store.
99monguse is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
» May 2013
» Car Care Brands
