Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Member
    Apr 2014
    98
    Re: Best Practice - Avoid buffing on top of body lines and edges
    Yeah that,s nice to know about it.As you know all the work is on your hands.So carefully use it and don it well.Avoid buffing on the top of the body and on the edges is actually a big point.Mostly some buffing doing on these without your expectation so be careful of it.
  2. #22
    Senior Member StuDLei's Avatar
    May 2012
    328
    Quote Originally Posted by swanicyouth View Post
    This is why I don't apply LSPs by machine. How do you get ALL the edges, around emblems, etc... ??? I guess you could go back and do it by hand on those areas, or you could just do the whole car by hand in one trip around. The later seems to make more sense to me.
    Some LSPs don't stain trim/emblems, so can't you just not worry about being super careful? Going over body lines for one pass with a pad that's spinning slowly, has no cut, and with an LSP that doesn't have any cut doesn't seem like much to worry about to me? I'm not a pro though.
    Most of the time you don't really have to buff directly on top of a hard line either. You can run that pad up close to it and let the edge graze it a little bit. There not really much pressure then.
    IDK, anyone understand what I'm trying to say?
    Thank you Autogeekers!
  3. #23
    Oct 2016
    What is recommended in regard to buffing relatively gently rounded corners, such as the transition from hood to front fender? Has this been covered elsewhere?
  4. #24
    Senior Member Cruzscarwash's Avatar
    Oct 2015
    Desert of California
    806
    that's a new panel, so for me its a new pad and re-priming the pad with product and starting over. I would never transfer straight from hood to fenders, MAYBE fender to another fender on the other side but not usually.
  5. #25
    Oct 2016
    What I'm getting at is a gently rounded corner, the transition from horizontal to vertical surface. Or around the back of a hatchback. Check out a late model Acura RDX to see what I'm asking about.
  6. #26
    Jun 2009
    Stuart, Florida
    35,528
    Quote Originally Posted by duquephart View Post
    The title of this thread starts with...
    best practice
    Of course there are lots of variables. I'd say you're safe to buff these areas unless some hack detailer has over-compounded them in the past.
    Remember, paint is always thinnest on high points, edges and raised body lines and the horizontal surfaces are usually the most damaged over time due to exposure to the sun, the elements and also because they are easiest areas to buff.
    Host - Competition Ready on Velocity Channel
    IDA Board Member
    CD-SV, RT
    Competition Ready Facebook Page
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Click on a book to get your own copy.
  7. #27
    Oct 2016
    The relative new post/video "Hats off to Meguiars - How to Polish your Motorcycle or Car" may have answered my question about buffing around corners. Any problems with the author's technique? Why not machine apply the wax?
  1. Body lines
    By Dman81 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 08-07-2015, 10:32 PM
  2. Polishing and Body Lines
    By Corey06 in forum Ask Mike Phillips your detailing questions!
    Last Post: 05-29-2015, 09:45 PM
  3. Taping raised lines/edges?
    Last Post: 03-09-2014, 08:13 AM
  4. Buffing around handles and contours and body lines
    By silvermesa in forum Auto Detailing 101
    Last Post: 06-06-2012, 09:48 PM
  5. How to avoid dry buffing
    By sqeekykleen in forum Auto Detailing 101
    Last Post: 09-14-2008, 03:57 PM
» March 2017
262728 1 2 3 4
