OK peeps I had a chance to clean up the stang and decided to do a review (show off
First up PB BnB I started by cleaning the wheel with my Megs wheel brush and Quick and Easy (QEW) car wash soap. Then I dried the tires thoroughly with my Autogeek Mango mf towels. Using a foam paint brush (makes spreading it easy and even) I applied a thin line across the tip of the brush and "painted" it on (makes for less waste as well).
Before
After
Next up one of the best products I used is PB Trim restorer. I made sure during the wash that I really cleaned the trim so to have a good surface to work on. I used a mf towel but would recommend the foam paint brush technique, the mf towel absorbed it more then spread it around (I used a foam paint brush before and it worked spreading it better) so I used more then last time :-[. Using the mf towel and using as little as possible product I started with nice and even stroks over lapping each other slightly. If your trim is in really bad shape (like mine) it will streak at first you just need to let it sit of about 10 min then go over the area again. I did 2 coats to ensure full coverage and my trim was really faded and needed it.
Before:
After (2 coats and buffed 10 min after last coat to ensure removal of any excess)
Here a during application snap shot:
I also used for the first time since bought Clearkotes Quick Shine quick detailer and I must say I was very impressed at the gloss and wetness (also WOW) factor after use. I sprayed a mist of QS to each panel and buffed using my PB mega plush mf towel.
Any comment welcomed...
