08-30-2007, 03:49 AM
|  | Senior Member | | Join Date: Aug 2006 Location: Gaffney SC
| | | 99 Jeep/ review Washed Duragloss #901 soap with 1oz #951 (Aquawax) in 5 gallons bucket and foam gun. DG# 471 bug remover on the front end Duragloss #701 Whitewall Tire Cleaner on the tires Poorboy’s Spray and Rinse Wheel Cleaner and power puff on the wheels. Tail pipe and gas tank Poorboy’s Spray and Rinse Wheel Cleaner Dry with guzzler and leaf blower Door jams #521 Marine & RV Detail Spray mix with 3oz #951 (Aquawax). Oh yes a higher gloss QD. Thanks Al… Clay The yellow stuff. The good stuff! I have good friends. Paint Polish #1 Menz Powergloss compound with orange Edge pad PC setting 5-6. Paint Polish #2 Duragloss #501 (Marine RV Polish)Can we say slick as owl crap! Done by hand with Polishin’Pal. LSP Duragloss #105 (Total Performance Polish) Think Sealant LSP Outside Glass Duragloss Nu-Glass #755 to get the acid rain and water spots off, used with Rotary Yellow pad 1500rpm.Then top with Duragloss #501 (Marine RV Polish). Outside Plastics and Rubber Duragloss #531 Marine & R/V Protectant, it work on the rubber with this vehicle. Wheels Wells Cleaned with DG#701 and top with Duragloss #265 (Ultimate Detail Spray) Comments and review under Engine Dressing Tire dressing Armor All Extreme Tire Shine Gel Inside Glass (NEW) I used this with my Cobra MF glass cleaning towels. Sprayway I thought there was nothing better than Stoners. This stuff is just as good, if not better. Talk about cleaning the dirt, oil, grime and tar from smoker off (that yellow stuff), with no streaks at all. You can see the yellow tar melting off. The only Thing I really didn’t like is it only come in a can. I like the pump bottle better. Or I might be use to Stoner’s pump.A-Law! For crystal clear and streak free glass this is it. Dang, I still have 5 bottles of stoners IG. What to do with them now? 5 Stars all the way…….. Still using what Strokin04 sent me. Thanks buddy again! Cleaned carpet, leather and vinyl with DP Interior cleaner. The Bananas stuff. Leather, vinyl and plastic Duragloss #201 Engine Cleaned with Awesome APC. Headlights Wolfgang Plastik Lens Cleaning System Engine Dressing (NEW) Thanks Big AL! Duragloss #265 (Ultimate Detail Spray) Big Al told me if I like CD2, I would love #265. He is Right! In the pass I could pick up CD2 at AutoZone, but haven’t seen it in over a year. So I pick up some #265 and it work great on the engine, vents and inside of the wheel wells. Another 5 star product! I believe this is the best spray shine product I have ever used. I’ve used a lot. DG web site said: (Is a blend of synthetic siloxanes. This convenient aerosol spray gives a "wet look" appearance with one easy application. Works great on tires (black or whitewall), bumpers, moldings, door jams and AC vents.)This is from Al. "you will like it...do not over spray it....just make sure motor is dry..then spray on and start the engine and let it run a few and shut off..the heat will set it up...."
I just did mine the other day....I did a wipe down since my engine is clean...sprayed and let warm motor dry the 265.... Comments, Suggestions, and Questions are Welcome Before pics
__________________ |
08-30-2007, 03:54 AM
08-30-2007, 03:58 AM
| | Before and after Pics of headlights. Note water got on the inside of the light.
After
08-30-2007, 06:07 AM
|  | Senior Member | | Join Date: Apr 2007
| | Damn sparkie!! You are the man  Just look at the interior, outside and engine!! Everything is great  Sweeeeeeet job! And the review of DG products, great!! I have to look into more DG. Its a great line!
Very nice job!
__________________
Audi Allroad Quattro
VW Jetta 4 TDI
08-30-2007, 06:34 AM
|  | Senior Member | | Join Date: Mar 2006 Location: Mass.
| | | Sparkie...another nice job...every thing looks great..the interior is impressive....looks like every thing worked out good for you....and it shows...Jeep looks fantastic.....
The 531 worked good for you this time?....
I told you ..you would like the 265..its very nice stuff....does up engines nice als wheel wells....as you seen....I have been using on the trim after a was...I just spray a MF with it and do a wipe down...I actually took wax stains off a car in work with it on a Ford truck..he waxed the door handles and I used 265 on it and they came out real nice...did have to rub it in a few times....
Now I told you my secret on the 521 and 951 mix...and you like it?....makes a real nice product...call it 1472..... it gives it a extra punch in the looks and cleans while doing it....
Glad every thing worked out for you...
Again Superb Job....I have 1 or 2 more secrets for you...lol....
AL |
08-30-2007, 08:14 AM
| | Member | | Join Date: Aug 2007
| | Quote: |
Originally Posted by sparkie Washed Duragloss #901 soap with 1oz #951 (Aquawax) in 5 gallons bucket and foam gun. DG# 471 bug remover on the front end Duragloss #701 Whitewall Tire Cleaner on the tires Poorboy’s Spray and Rinse Wheel Cleaner and power puff on the wheels. Tail pipe and gas tank Poorboy’s Spray and Rinse Wheel Cleaner Dry with guzzler and leaf blower Door jams #521 Marine & RV Detail Spray mix with 3oz #951 (Aquawax). Oh yes a higher gloss QD. Thanks Al… Clay The yellow stuff. The good stuff! I have good friends. Paint Polish #1 Menz Powergloss compound with orange Edge pad PC setting 5-6. Paint Polish #2 Duragloss #501 (Marine RV Polish)Can we say slick as owl crap! Done by hand with Polishin’Pal. LSP Duragloss #105 (Total Performance Polish) Think Sealant LSP Outside Glass Duragloss Nu-Glass #755 to get the acid rain and water spots off, used with Rotary Yellow pad 1500rpm.Then top with Duragloss #501 (Marine RV Polish). Outside Plastics and Rubber Duragloss #531 Marine & R/V Protectant, it work on the rubber with this vehicle. Wheels Wells Cleaned with DG#701 and top with Duragloss #265 (Ultimate Detail Spray) Comments and review under Engine Dressing Tire dressing Armor All Extreme Tire Shine Gel Inside Glass (NEW) I used this with my Cobra MF glass cleaning towels. Sprayway I thought there was nothing better than Stoners. This stuff is just as good, if not better. Talk about cleaning the dirt, oil, grime and tar from smoker off (that yellow stuff), with no streaks at all. You can see the yellow tar melting off. The only Thing I really didn’t like is it only come in a can. I like the pump bottle better. Or I might be use to Stoner’s pump.A-Law! For crystal clear and streak free glass this is it. Dang, I still have 5 bottles of stoners IG. What to do with them now? 5 Stars all the way…….. Still using what Strokin04 sent me. Thanks buddy again! Cleaned carpet, leather and vinyl with DP Interior cleaner. The Bananas stuff. Leather, vinyl and plastic Duragloss #201 Engine Cleaned with Awesome APC. Headlights Wolfgang Plastik Lens Cleaning System Engine Dressing (NEW) Thanks Big AL! Duragloss #265 (Ultimate Detail Spray) Big Al told me if I like CD2, I would love #265. He is Right! In the pass I could pick up CD2 at AutoZone, but haven’t seen it in over a year. So I pick up some #265 and it work great on the engine, vents and inside of the wheel wells. Another 5 star product! I believe this is the best spray shine product I have ever used. I’ve used a lot. DG web site said: (Is a blend of synthetic siloxanes. This convenient aerosol spray gives a "wet look" appearance with one easy application. Works great on tires (black or whitewall), bumpers, moldings, door jams and AC vents.)This is from Al. "you will like it...do not over spray it....just make sure motor is dry..then spray on and start the engine and let it run a few and shut off..the heat will set it up...."
I just did mine the other day....I did a wipe down since my engine is clean...sprayed and let warm motor dry the 265.... Comments, Suggestions, and Questions are Welcome Before pics | very beautiful work  \\
08-30-2007, 08:16 AM
| | Quote: |
Originally Posted by Al-53 Sparkie...another nice job...every thing looks great..the interior is impressive....looks like every thing worked out good for you....and it shows...Jeep looks fantastic.....
AL | Time to get some new DG products for me...btw very glossy! The reflection is like crystal clear.  I was looking for CD2 for a long time but could never find it so, I settled for the autozone one..so maybe I will try the DG.  |
08-30-2007, 02:23 PM
|  | Senior Member | | Join Date: Oct 2006 Location: Norway
| | | Looks great Sparkie, great review as always..
Is it a brand name "inside glass"?
__________________ EVOIX |
08-30-2007, 02:25 PM
|  | Senior Member | | Join Date: Nov 2006
| | | Just a very fine work Sparkie. Well done my friend! |
08-30-2007, 02:57 PM
|  | Senior Member | | Join Date: Dec 2006 Location: OKC, OK
| | | Wow Sparkie amazing turn around on the headlights. Oh and the rest of the jeep looks 100 times better also. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » November 2008 | | S | M | T | W | T | F | S | | 26 | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | |
