05-30-2007, 12:58 PM
|  | 24 HR Queue | | Join Date: May 2006 Location: Blue Ridge GA (The Mtns.)
| | | Detailed: 2006 Springdale Camper This one has been sitting in my Photobucket account for about 2 weeks now. I know this is RV/Camper season so I thought I'd post this to help anyone out that has their own to do. This was a new process to me and took me about 3 hours. Now, after doing it, I could easily do the same camper again in half the time. Here's the process.... Wash Cycle: (Camper Cleaning solution via pressure washer and Detailing4U Foam Gun) Ok, here's my camper solution: 1/3 Purple Power, 1/3 Tilex, and 1/3 water.......all in a 32oz. bottle. I then connected it to my foam gun and went to work.......if that's what you call it!!! I stood at the front and easily did an entire side without moving. This was an easy 20 ft. The foam stayed on the camper's panels for at least 10 minutes. It slid down very slowly. This combination of detergents and mildew killer did the job. After letting soak for about 15 minutes, I took a wash brush to the panels. Everything came off when I rinsed. I did not need to go back a second time. This included the dreaded black streaks. Protection: (2 ounces of Souveran spray wax, a few ounces of Meg's Last Touch, and water via the foam gun) This really brought a reflective luster to exterior panels. I foamed the solution on and let soak for about 10 minutes. I then rinsed. I intentionally let it air dry to see if any spotting occurred. None did. Even in full sun.......even on the glass. After drying, the panels felt soft like a hand wax had been reapplied. This process allowed me to keep the cost down for the customer and the time down for me. This way, there was profitability for the both of us. The waxing may only last a month, but this inexpensive service has my customer coming back to me monthly now! Total time: 3 hours Payment: 150.00 Befores....... Foaming....... Foaming and chemicals working....... Preparing to wax.... |
05-30-2007, 01:25 PM
|  | Senior Member | | Join Date: Mar 2006
| | Another well job done, Justin. Quote: |
Originally Posted by justin30513 Wash Cycle: (Camper Cleaning solution via pressure washer and Detailing4U Foam Gun) Ok, here's my camper solution: 1/3 Purple Power, 1/3 Tilex, and 1/3 water.......all in a 32oz. bottle. I then connected it to my foam gun and went to work.......if that's what you call it!!! I stood at the front and easily did an entire side without moving. This was an easy 20 ft. The foam stayed on the camper's panels for at least 10 minutes. It slid down very slowly. This combination of detergents and mildew killer did the job. After letting soak for about 15 minutes, I took a wash brush to the panels. Everything came off when I rinsed. I did not need to go back a second time. This included the dreaded black streaks. Protection: (2 ounces of Souveran spray wax, a few ounces of Meg's Last Touch, and water via the foam gun) This really brought a reflective luster to exterior panels. I foamed the solution on and let soak for about 10 minutes. I then rinsed. I intentionally let it air dry to see if any spotting occurred. None did. Even in full sun.......even on the glass. After drying, the panels felt soft like a hand wax had been reapplied. | New process to me. But sounds nice, and especially if it works. Keep us updated on it's durability.
Maybe another nice one would be using Duralgoss AW.
__________________
1997 Acura 3.2 TL (sold)
|  | Senior Member | | Join Date: Mar 2007 Location: flower mound, TX
| | | wow...really nice job...i cant wait to use your gun..i have 6 RV's to do in a few weeks...so...a little clearity...after you sprayed the wax on ...did you dry the rv..or let air dry and just dry spots that didnt really dry as much? |
05-30-2007, 01:29 PM
| | Quote: |
Originally Posted by scottgt wow...really nice job...i cant wait to use your gun..i have 6 RV's to do in a few weeks...so...a little clearity...after you sprayed the wax on ...did you dry the rv..or let air dry and just dry spots that didnt really dry as much? | I let it completely air dry. |
05-30-2007, 01:32 PM
| | | oo..ok cool...man that seems like a really good process for the rv |
| | Senior Member | | Join Date: Apr 2007 Location: Edmundston, NB
| | My friend just bought a camper, I guess I will have to try this when my detailing4U foam gun arrive Great idea for the QW/Megs FT mix, seams to have worked like a charm! |
05-30-2007, 01:35 PM
| | | The possibilites are endless! You will be wanting to foam everything!!!! |
05-30-2007, 02:03 PM
|  | Senior Member | | Join Date: Nov 2006 Location: South Florida
| | | It came out looking very nice and clean. |
05-30-2007, 02:24 PM
| | Very nice. Its shines
__________________
Audi Allroad Quattro
VW Jetta 4 TDI
|  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » November 2008 | | S | M | T | W | T | F | S | | 26 | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | |
