2011 Mini Cooper S - full paint correction and Opti-Guard and CQuartz coating
Show N' ShineDiscuss 2011 Mini Cooper S - full paint correction and Opti-Guard and CQuartz coating in the Auto Detailing Forums forums; Did this car a little while ago and just now getting some time to post it up. Owner brought this ...
Did this car a little while ago and just now getting some time to post it up. Owner brought this in as a basically brand new car with hardly any miles on it. After having key parts wrapped in satin vinyl and getting clear bra installed on the front end, the task was to fully correct the paint and permanently protect it with Optimum Opti-Guard. The paint, plastics, wheels, and lights would all be coated with Opti-Guard and the glass would be coated with CQuartz.
About 20 hours altogether.
Upon arrival
Swirls on the A-pillar
Swirls and RIDS (Random Isolated Deep Scratches) seen on the hood
Some swirls in the clear film that would require some correction
Spraying the wheels down with Sonax Full Effect Wheel Cleaner, a pH balanced cleaner safe for all wheel types.
The Mini Daytona Speedmaster Wheel Brush getting the wheel barrels nice and clean.
Inner barrels looking great
Foaming the car with a mix of Dawn and APC
Using the Swissvax detail brush to clean up the hard to reach areas
Re: 2011 Mini Cooper S - full paint correction and Opti-Guard and CQuartz coating
You did a truely awesome job on this car, still hard to believe a new car needs so much attention but you've proved it once again, doesn't matter if its new, it still needs attention. Now those wheels, although they match the car's theme, there's NO WAY IN HELL I'd ever have gloss black wheels on anything, even if it were a toy, NO WAY IN HELL!
I had an R56 that I bought new in 2007 and had to turn in after the lease was up, nothing but trouble with the car, it seems they don't do well in the cold and have troubles with the aux fuel pump, went through 3 of them, a fuel injector, frozen throttle, new intake manifold under warrenty, new timing chain (thankfully done under warrenty!!!) and finally a MAF, not under warrenty. Wish your client good luck with the car, I looked forward to getting in it everyday though, loved that car!
__________________ 2011 Honda CR-Z EX/6MT/Storm Silver Metallic "Some say...he likes Swedish fish because they're made with caranuba wax" Current surface protection count...(83-37)
X2 on the pillars. Also what was the procedure on the roof.
I just polished out my pillars and roof and opti-coated them. Wasn't too bad but effort had to be put in. The pillars swirl up after one wash, hopefully the Opti-coat protects from that.
Also x2 on the mini having problems. 08 mini cooper s 30k miles here. Had to replace the thermostat housing and rebuild the head cause the timing chain snapped :-(
