Quote:
Originally Posted by ltoman toto, wish i had your skills! |
Thanks so much Lauren. Just remember, 7 months ago, I had never used a rotary, never wet-sanded, thought cutting pads were a last ditch fix, didn't even know that plastic body panels could burn so easily, never used glaze (except for XMT Glaze with Carnuba)....
I've had a good teacher with the dealer. But we've had our differences and work them out. For instance, his prior detailer came from a body shop environment and could cut paint, wet sand, and would use the rotary with a cutting pad/compound until the sheet metal (hood, trunk, etc) "popped" from the heat. The dealer thought this was the way to compound paint and I disagreed.
Well, just a few weeks ago, the dealer went to his painter and the guy told him that excess heat is flat wrong on today's paint. Using different pad and product combo's are the correct way with today's paint. Super heating painted metal is walking a fine line between correction and disaster.
So, now the dealer likes the way I use products safely. It's always a learning process in this field.
If there is one major point I've learned: Try an area start-to-finish (trunk, fender, etc) before tackling the rest of the car. That way you have the process of what's needed.
Toto
