02-27-2007, 06:18 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Overland Park KS
| | | P1et: those wheels are different from the X5 I think...getting so I can't remember with the Bimmers rolling thru the shop LOL!
Woob: The Ultrafina SE definitely is expensive ($35 approx) and the accompanying pad is high too ($18), but the dealer wanted to try out the system as he favors 3M products a lot. We are probably going to use this on black BMW's as the finish is critical for showing where silver is much more forgiving.
Toto
__________________ |
02-27-2007, 09:56 PM
|  | Senior Member | | Join Date: Jul 2006 Location: NC/BC
| | Quote: |
Originally Posted by Totoland Mach P1et: those wheels are different from the X5 I think...getting so I can't remember with the Bimmers rolling thru the shop LOL!
Toto | Yes 3M is trying to gear up their polish finishes, I honestly think they're a bit behind on development. Very shop friendly, and when used right will work on alot of clearcoats. Is the pad any good? Pic? #18 is alot, basically 1 Edge pad. Do you even get 32oz for the Ultrafina? |
02-27-2007, 10:06 PM
| | Quote: |
Originally Posted by Woob Yes 3M is trying to gear up their polish finishes, I honestly think they're a bit behind on development. Very shop friendly, and when used right will work on alot of clearcoats. Is the pad any good? Pic? #18 is alot, basically 1 Edge pad. Do you even get 32oz for the Ultrafina? | The pad is a light blue waffle stype 8" pad which is very think and soft...softer than the Meguiar's #9006 unit.
Yep..the Ultrafina is 32 oz for that price.
I'd looking at the Ultrafina to replace a glazing step in order to save some time on the dark Bimmers.
I'd like to try the Menzerma line sometime...I hear good things about it.
Toto
02-27-2007, 10:11 PM
| | Quote: |
Originally Posted by Totoland Mach The pad is a light blue waffle stype 8" pad which is very think and soft...softer than the Meguiar's #9006 unit.
Toto | Hmm not bad for the price, but Ultrafina I heard was pureply as a Finishing Polish (Not Flexible). I personally use Blackfire Scratch Resistant Polish, which is rebottled Menzerna 106FF. 106FF you can use to cut as a medium abrasive, then finishes out as equal to Final Polish 2 or better, and it finishes better than Optimum Polish.
106FF or Opt Polish. The new Dark BMW's are such a pain, pad/machine dependent as well as product. |
02-27-2007, 10:26 PM
| | Quote: |
Originally Posted by Woob Hmm not bad for the price, but Ultrafina I heard was pureply as a Finishing Polish (Not Flexible). I personally use Blackfire Scratch Resistant Polish, which is rebottled Menzerna 106FF. 106FF you can use to cut as a medium abrasive, then finishes out as equal to Final Polish 2 or better, and it finishes better than Optimum Polish.
106FF or Opt Polish. The new Dark BMW's are such a pain, pad/machine dependent as well as product. | That's good to know and you're right about Ultrafina not being a final product. I usually finish up the Bimmers with Meg's #26 because it doesn't dry white (which drives the dealer nuts).
I might try a sample of 106FF. I've seen some nice forum write-up's and pics.
Toto
03-01-2007, 07:29 PM
|  | Senior Member | | Join Date: Oct 2006 Location: Norway
| | | Great work toto, as always..
__________________ EVOIX |
03-02-2007, 04:39 AM
| | Quote: |
Originally Posted by Totoland Mach That's good to know and you're right about Ultrafina not being a final product. I usually finish up the Bimmers with Meg's #26 because it doesn't dry white (which drives the dealer nuts).
Toto | If it's either 106FF (Straight Menzerna) or the Blackfire SRC, this is what I recommend via Rotary:
Heavy Compounding - Opt HC via Cutting/Polish Pad (Anything Heavy anything that would require at least 2 buffing stages)
106FF Via Polishing Pad.
Wax/Seal
That's the beauty of it, the fact that you can cut at a medium abrasive level and not need a finishing polish. Add also that it's one of the top, if not best finishes you can see. |
03-02-2007, 06:55 AM
| | | Thanks for the info Woob! I think I'll get a small bottle to sample. I've got another bunch of Bimmers coming to the shop in the next few weeks, and I'll give that process a try.
Toto
03-02-2007, 08:18 AM
|  | Senior Member | | Join Date: Apr 2006 Location: Cobb county, GA
| | | ToTo, great job on the Bimmer. Working on a lift makes it alot easier doesn't it. No bending over and standing up. Glad I don't have to do BMW rims all the time, since most are a pain in the butt.
I have a sample of the 3M Ultrafina, haven't tried it yet. From what the guys at the shop say it works very well. You do need the light blue pad with it too.
Ed |
03-02-2007, 08:34 AM
| | Quote: |
Originally Posted by HighEndDetail ToTo, great job on the Bimmer. Working on a lift makes it alot easier doesn't it. No bending over and standing up. Glad I don't have to do BMW rims all the time, since most are a pain in the butt.
Ed | Thanks for the compliment Sir! The lift is a real asset in productivity. The BMW's are notorious for brake dust and the dealer has a wheel acid for them (but lots of care has to be taken using acid).
We have 2 of the light blue Ultrafina pads and they work well...word of caution, is they are so soft that hitting any edge will tear some of the waffle pattern.
I'm still going to give Menzerma a shot to guage finish/speed of use/etc.
Toto
__________________ |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
