02-02-2007, 02:28 PM
|  | Moderator | | Join Date: Mar 2006
| | I cannot believe your customer said that car was "pretty clean" That thing was a mess! You really had your work cut out for you on that one and you made it look as good as new! The Souveran makes the trees look like they're growing out of the car! Awesome work Justin. I love the technique of using the shmitt on the interior detail. I never thought of that before. I always use Woolite and water and a spong or MF for interior details and I can see how the shmitt would save tons of time. Thanks for passing that technique along. I'll definitely use that one. Oh, can another fabric softner be used besides Snuggle? I always buy Suavitel. I like the fragrance of that one better than Snuggle and I don't have any pets so if I did have to remove hair it would just be a customer's car. That's a great tip. Thanks for sharing it.
__________________ Oye como va mi ritmo bueno pa gozar |
02-02-2007, 06:36 PM
|  | Senior Member | | Join Date: Aug 2006 Location: Mountville, PA
| | | Very nice!! The Pinnacle twins worked well. Interior looks great now. Souveran on the dash gave that wood a nice rich glow. Thanks for the tips on pet hair.
__________________
Alban B-)
2008 Ford F250 XLT 6.4L PSD, 4X4, SC, SB, Bedrug bedliner, Torza Trifold Tonneau cover, SS step bars / Dark Shadow Gray Metallic
2006 Nissan Sentra 1.8S / Inferno |
02-03-2007, 01:32 AM
|  | 24 HR Queue | | Join Date: May 2006 Location: Blue Ridge GA (The Mtns.)
| | Quote: |
Originally Posted by FloridaNative Oh, can another fabric softner be used besides Snuggle? | Sure. All softeners have anti static properties. I like the added scent left by this process.
I'm telling you, the Wheel ShMitt cut my leather cleaning time in half! Made it so easy! Worked awesome on the door panels too.
Next week it get's tried on mats! |
02-03-2007, 01:47 AM
|  | Senior Member | | Join Date: May 2006
| | | Wheel ShMiTT works great, but we do make an interior ShMiTT just for that purpose that is the Yellow foam on one side, and the soft White on the other. The Yellow is just coarse enough to scrub all interior surfaces, and it shows the dirt comming off on the yellow so its easy to know when to rinse it, unlike the black that we made to take off brake dust and we did not want it to show black brake dust which stains the white and the yellow badly. The soft white side on the back is nice to apply leather conditioner or dressing to seats and dash. The origonal wheel and interior mitts were flat foam but many people said they did not squish easy enough and were hard to bend and get into alot of tight spots, so we changed all the mitts to the wave waffle texture.
From AutoGeeks site: Yellow/White Interior Shmitt: Clean interior surfaces with this slightly coarser yellow foam. The yellow foam can be used to safely clean leather, vinyl, dashboards, and door panels. Since these materials are often textured, the light scrubbing ability of the yellow foam expertly cleans uneven surfaces. The beveled edge allows you to effectively clean the seams and crevices of your vehicle’s interior. The mitt design makes it quick and easy to clean curves, corners, concave spaces, and crevices without dropping your ShMITT.
The white backside of the Interior ShMITT is the same soft, absorbent foam found in the original Wash ShMITT. This smooth, soft foam applies leather conditioners and protectants in a thin, even coat with no mess. Easily follow the curves of interior surfaces with the comfortable ShMITT to apply products all over, even the sides of the seats that were formerly hard to access. |
02-03-2007, 11:00 AM
|  | Senior Member | | Join Date: Mar 2006 Location: Dallas, TX
| | | Justin, tell me more about using Soveren on the wood dash bits. I've tried several things on mine and I don't know what is best. The wood has a thick layer of what I assume is polyurethane (sp?) so using wood proc\ducts like pledge seems pointless. In fact I have tried pledge. Now I use PN Natural look with the rest of the dash. what does using a carnuba wax do?
That Jag is the same color as mine. I'm kind of bummed you used Soveren. It looks so darn good I may have to make the plunge and buy some. It's so expensive!
__________________ _____________________________________ 2003 Jaguar S-Type V8
2001 Nissan Quest SE
2000 Nissan Frontier XE
"Dogs in cars again. Going away. Going away fast" - P.D. Eastman, Go, Dog. Go! |
02-04-2007, 01:44 PM
|  | Senior Member | | Join Date: Apr 2006
| | | What does a job like that cost?
Thanks Ryan |
02-04-2007, 02:05 PM
|  | Senior Member | | Join Date: Aug 2006 Location: Gaffney SC
| | | WOW, I'm like OMG! You turn that car around! I can't believe somebody will let a Jag look so bad. You do awesome work bro!
__________________ |
02-04-2007, 02:18 PM
| | Quote: |
Originally Posted by mingraygt What does a job like that cost?
Thanks Ryan | This one took 4 hours and cost 250.00. I gave a discount for using me so much. This was before seeing it was hair infested! Oh well. Still was fun making it completely turn around! |
02-04-2007, 02:20 PM
| | Quote: |
Originally Posted by Reddwarf Justin, tell me more about using Soveren on the wood dash bits. I've tried several things on mine and I don't know what is best. The wood has a thick layer of what I assume is polyurethane (sp?) so using wood proc\ducts like pledge seems pointless. In fact I have tried pledge. Now I use PN Natural look with the rest of the dash. what does using a carnuba wax do?
That Jag is the same color as mine. I'm kind of bummed you used Soveren. It looks so darn good I may have to make the plunge and buy some. It's so expensive! | I used Souv to give it a nice glow and finish for the interior pieces. And to just say I did!!! Not many other detailers take the long time (lol! 5 minutes!) needed to do this little step.
I'm telling you, get Souveran. It's 80.00 but if used only on one to two cars, it will last you forever!!! |
| | | Looks dang good! |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
