Re: 64 Nova SS Revived from the dead by Tru Shine
after the car was washed, I then rinsed it one last time.
To any detailers out there that have to detail in the cold weather. These gloves are AMAZING! They keep your hands Dry and Warm.
Next is the Clay bar step. This car had little tree sap spots all over it
Its kind of hard to see, but if you look close, these were all over the paint and windows.
here is the clay bar after finished, I had to kneed it a few times too.
So then the car was pulled inside for the rest of the job.
I started out with doing some touch up. there were a lot of spots to cover and I new it would take some time.
This touch up was more for just making them chips less noticeable. there were a lot of rusty spots that needed the rust scratched out of them and touch up paint applied.
here is one area were I removed the rust out with the corner of the razor blade.
after both of the scratches were cleaned.
Next I applied the touch up paint.
I apply a couple of layers and then let it all dry before I wetsand it smooth.
While the touch up paint dries, I start the paint correction on the lower sides of the car.
here are some pics with the Halogen lights.
And here is a 50/50
And then the Final outcome of this fender.
I experimented with different methods starting off.
My first choice was the FLEX 3401 and PFW pad using Meguiars M105.
It left some marks on the paint so I followed behind it with the Lake country Cyan pad and M105 to get those out.
It did alright, but I really wanted to use my Griots garage DA and a Surbuff R-series pad. I like the flex, but it takes a lot of back muscle to work it, and with the DA and surbuff pad, its just so smooth and cuts amazingly. Once you master the Surbuff pad you can correct the paint better and faster then a Rotary buffer with a wool pad.
So on the next panel I pulled out the Griots and Surbuff pad and got at it.
After making it down the driver side, I started on the trunk using the Griots 6in DA and Surbuff working in 2'-3' squares
Here is some of the progress
"I don't know what's worse, running out of M105 or running out of toilet paper" -Dave Saunders
Truly amazing work. It looks like that car has a brand new coat of paint on it when you finished!! I think the customer can put of a retoration for quite a while now. GREAT work!!!
Great work Eric! That's one of my favorite classic cars too!
That must have been 1 happy customer. I have to say between this write up and the one you did on the Ferrari, im inspired. you really captured the magic my friend. you made me buy a camera after the Ferrari thread (got an Olympus). doing a G35 this weekend, hope to make a good writeup w/ good pics like this one.
Thanks Everyone
The camera I used for this write up is a Nikon d3000, and the one for the ferrari is a Nikon Coolpix p500. both are very good
Very nice work and you did a really nice job of capturing the before, process and after pictures.
I have an article that explains the importance of capturing the before pictures because it's the before pictures that give the after pictures their power.
The power in the after shots is created in the before shots
Thank you for taking the time to put down your tools, frame-up and take great pictures, then after all the hard work of detailing the car was done, processing the pictures, adding words and creating a write-up that documents your process and will undoubtedly inspire others to follow your footsteps to success.
Awesome results, awesome write-up.
By Justin at Final Inspection in forum Show N' Shine
Last Post: 08-26-2019, 06:33 AM
Last Post: 05-10-2019, 04:58 AM
Last Post: 03-10-2019, 05:52 PM
By Charleston in forum Show N' Shine
Last Post: 12-30-2012, 02:09 PM
By Tru_Shine in forum Show N' Shine
Last Post: 09-16-2011, 10:49 AM
