After reading Justin’s review of DP 4 in 1 as well as several others on this forum I decided to give it a try. Today it was around 50 degrees and cloudy. Not all that cold, but cold enough that I wanted to try the rinseless wash and avoid using the hose.
I was hesitant because my car was rather dirty. We have had a bit of rain and the car had lots of dirty spots.
Here is a shot of the front wheel before:
The dirty side:
The dirty top:
I filled my bucket with 3 gallons of warm water and 3 oz of DP 4 in 1. I filled a second bucket with warm water. The product is very interesting. It is such a different experience than the normal wash process. There are no suds and it seems queer to wash and dry a panel at a time. I used a Schmitt and I was amazed at how well the dirt came off. It was easy to dry with the Guzzler. I used the Wheel Schmitt after the car was done. It did not clean the wheels as well as using a wheel cleaner like DP Wheel Cleaner, but it did pretty darn good.
After Pictures:
I would rather wash with the foam gun and hose, but this process work well and it was comfortable doing it in cool weather without using the water hose.
Overall I’m very impressed with the product and the results. As I said, my preference is the usual wash, but I will definitely do this again.
After the DP 4 in 1 Rinseless wash, I used Poorboy Spray & Wipe on a few spots and followed by DP Krystal Vision on the glass and finished with a spray and buff of Clearkote Quick Shine. After I took the pictures I applied a coat of DP Tire Gel to the tires.
My Schmitt has never been so dirty (proof the 4 in 1 cleaned the car!). Anyone have a recommendation on cleaning it?
