Go Back   Auto Geek Online Auto Detailing Forum > Auto Detailing Forums > Show N' Shine
Featured Photos
by Meghan
Sema Show 2008
433 photos
13 comments
by admin
Pinnacle Products
11 photos
20 comments
by admin
531 photos
29 comments
by admin
Motorcycles
4 photos
1 comments
» Autogeek Car Care Products
Price match Promise
Tags: , , ,
Reply
Thread Tools Display Modes
  #11
Old 11-20-2006, 08:48 PM
Totoland Mach's Avatar
Here's a small pic of the mirror burn. The problem with plastic housings is they are almost impossible to correct with touch-up paint. It usually takes an air brush to get a decent blend. I'm more upset about this than the shop owner!
Toto
__________________
  #12
Old 11-20-2006, 08:52 PM
Whitethunder46's Avatar
Ouch. Think this is possible with a heavy compound and cutting pad on the PC?
  #13
Old 11-20-2006, 10:05 PM
Whitethunder: the shop owner said the problem with plastic is it can't take heat. The rotary will generate a lot of heat with compound where a pc does not really generate that kind of temperature. Still, a pc with a cutting pad and compound "might" do some damage in a thin area. I suspect the thickness of a mirror housing is thinner than a front bumper, hence the burn I did. I didn't have any problem with the rotary on the bumper after sanding and compounding.
Toto
__________________
  #14
Old 11-21-2006, 04:59 PM
sparkie's Avatar
Quote:
Toto
Can you believe I done something like that with my PC!
__________________
  #15
Old 11-21-2006, 05:16 PM
Truls's Avatar
ive burned the bumper on the volvo with the rotary (i had to buy a new one anyhow), but its scary how fast you "burn" plastic parts with it.
__________________
EVOIX
  #16
Old 11-21-2006, 05:23 PM
boy, you're right about quickly burning a plastic part. I'm starting on a metallic gray 540 and pointed out to the shop owner that it already has a tiny burn mark on the driver's side mirror....my eyes are getting sharper about where to look for paint damage before I start the work.
Toto
__________________
  #17
Old 11-21-2006, 06:03 PM
while we are somewhat on the subject.
I've once heard you can not use compounds and polish on bumpers (I guess because they're plastic).
From reading the little bit here, I have a feeling that is a myth, but you should be very careful? Even if simply using a PC?
  #18
Old 11-21-2006, 06:55 PM
justin30513's Avatar
24 HR Queue
Toto
Main difference between plastic and metal.....
Plastic absorbs heat and metall dissapates heat. I was trying to fix a scratch on the bumber of a Bug a couple of months ago and it just melted. I felt it and man, it just was holding a ton of heat in it. It was even gooey to a hard touch.
I'm getting a rotary and doubt I'll ever touch a bumper with it....well it will be a long time.
  #19
Old 11-21-2006, 10:21 PM
I started on another Bimmer tonight and did the lower portion of the car: bumpers, rocker panels...all plastic. Where there were scratches, I used Optimum compound and the rotary or the Festool in rotary mode (depended on working area) and kept the weight of the rotary off the painted plastic. It's a learning process and I would do a small area, wipe off the compound to check my work, and either stop or proceed to do more. Light pressure, light weight, and checking your progress often is the key to painted plastic.
I'll post some pics of this process tomorrow.
Toto
__________________
  #20
Old 11-21-2006, 10:37 PM
Nica's Avatar
Toto
Toto you , I love it when someone posts pics and process I just absorbe it all up.....still new here
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Quick (for me) BMW 545i and Sun Shots of 745Li both black Totoland Mach Show N' Shine 11 02-20-2008 07:43 PM
FMINUS Detailed: 2002 BMW 330Ci Silver FMINUS Show N' Shine 10 11-24-2007 11:02 PM
Silver BMW 545i Sport Finished Nicely Totoland Mach Show N' Shine 14 07-05-2007 12:23 PM
Silver BMW 330Ci Finished Menzerna plus Meguiars Totoland Mach Show N' Shine 17 06-14-2007 08:10 PM
BMW 545i Silver Gray Finished Totoland Mach Show N' Shine 17 02-20-2007 09:02 AM
» January 2009
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
