10-08-2006, 12:41 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Dallas, TX
| | | Nissan Quest - 303 & DP Sealant I washed the wife's Nissan Quest and used 303 for the first time. WOW! Am I impressed.
Last weekend I washed the Quest with Meg's GC (foam gun of course!) and clayed. I had planned to apply DP Sealant but I ran out of steam due to having a cold. However, I did apply 303 to the trim. I took a before picture of the trim, but it was accidently deleted. Anyway, the trim on the back has always caused me trouble. I usually apply Mother's Back to Black and it turns it from lots of grey spots to black. But within a couple of days the grey is back!
As you can see in the picture, it is still black after a week and a second wash.
Yesterday, I washed with Meg's GC, then applied AIO, then DP Sealant. As you can see in the photo there is a decent reflection without having used a PC and polish.
__________________ _____________________________________ 2003 Jaguar S-Type V8
2001 Nissan Quest SE
2000 Nissan Frontier XE
"Dogs in cars again. Going away. Going away fast" - P.D. Eastman, Go, Dog. Go! |
10-08-2006, 12:49 PM
|  | 24 HR Queue | | Join Date: May 2006 Location: Blue Ridge GA (The Mtns.)
| | | Very nice reflection.
I feel you on the cold. I've had one for the last couple of days.....sucks. |
10-08-2006, 12:59 PM
|  | Senior Member | | Join Date: Mar 2006 Location: San Diego
| | | Ditto on the cold!! I hate feeling like this. Nice work man, are those pumpkins in the reflection?! |
10-08-2006, 02:32 PM
| | | Pumpkins they are indeed. Decorated by my 5 year old son.
10-08-2006, 04:01 PM
| | Senior Member | | Join Date: Mar 2006 Location: Michigan
| | | Mothers back to black is meant to clean and restore trim by removing oxidation, old wax, dirt, etc. After it cleans and restores the trim a protectant/dressing product like 303 should then be applied to the trim. |
10-08-2006, 04:15 PM
| | Quote: |
Originally Posted by SVTContour Mothers back to black is meant to clean and restore trim by removing oxidation, old wax, dirt, etc. After it cleans and restores the trim a protectant/dressing product like 303 should then be applied to the trim. | Good point. I still like Mother's BtoB. It did an amazing job on the wheel wells of my Jag.
10-08-2006, 05:23 PM
|  | Senior Member | | Join Date: Aug 2006 Location: Mountville, PA
| | | Nice job! Thanks for the tip on the 303. I have the same problem with my trim.
__________________
Alban B-)
2008 Ford F250 XLT 6.4L PSD, 4X4, SC, SB, Bedrug bedliner, Torza Trifold Tonneau cover, SS step bars / Dark Shadow Gray Metallic
2006 Nissan Sentra 1.8S / Inferno |
11-08-2006, 01:33 PM
|  | Junior Member | | Join Date: Oct 2006 Location: Florida
| | | Do you think DP Interior Surface Protectant would also do the trick? |
11-08-2006, 01:38 PM
|  | Moderator | | Join Date: Mar 2006
| | Looks great Reddwarf!
fastgsx, if you are going to apply it after the Mother's back to black then it will protect the trim also. The DP has UV protection in it as well, although not quite as high as the 303.
__________________ Oye como va mi ritmo bueno pa gozar |
11-08-2006, 11:42 PM
|  | Senior Member | | Join Date: Aug 2006 Location: Gaffney SC
| | Awesome job Reddwarf. Sweet reflection. 303 you can't beat it, spf of 40. Every dressing I tried just says " has UV protection" 303 has it on the label 40. I done a test on dressing, all of them run in the rain. VRT- does not last; when it rains it’s gone. Some UV protections, Dose not say how much. It streaks a little. Mags #40 last longer, but it still runs. Has UV protection, Dose not say how much. Dose not streak on vinyl, streak a little on rubber. I think it works better on vinyl then rubber. Poorboys TR, It only works on my personal vehicles, vehicles I have tried other then mine IT STREAKS, don’t know way. The only thing I can think of is that my vehicles has had only water base products on them, no oil base silicon products on them. It last longer on rubber then vinyl in the rain. It says it has UV absorber, how much, don’t know! Surfer can tell yal all about it. TR Top Kote” RVL Protestant #108- Last longer then the others, close to 303, a little richer look. Runs in the rain! Has UV Inhibitors, don’t know how much. 303 Aerospace Protectant, it last longer then the others, still run in the rain, but not as bad. No streaks. UV protection, 40 spf. It’s the best I’ve tried so far. AIO- It works, no runs, its there. But I want something that has a richer, deeper look. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| 1 | 2 | 3 | |
