Nissan Quest - 303 & DP Sealant
Show N' ShineDiscuss Nissan Quest - 303 & DP Sealant in the Auto Detailing Forums forums; Could you also use Megs APC to clean the trim before applying 303?...
fastgsx, if you are going to apply it after the Mother's back to black then it will protect the trim also. The DP has UV protection in it as well, although not quite as high as the 303.
