Quote:
Originally Posted by sparkie The purple power is a strong APC you can buy OTC Wal-mart, NAPA, autozone, advance auto. I needed the power, simple green was not strong enough. After the rinse, I use black magic tire foam on the engine (cleans and shine). On the tires they wanted very wet shine. So I use Megs insane shine, but the tires just soak it up, went back with three coats of AA. Soak up the first two of AA, never seen that before. |
I've noticed that too on cars or truck with big tires, the gel just seems to disappear after one coat, is that because the tires are just big or becuase maybe they haven't had any other coats before to build up. I've heard that not completely cleaning off all the tire dressing each time you wash help when adding tire gel.
