car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
Go Back   Auto Geek Online Auto Detailing Forum > Auto Detailing Forums > Show N' Shine
» Official Detail Fest 2010 Information Thread!!
» Current Poll
What Discovery show do you watch most?
Overhaulin' - 25.53%
60 Votes
Deadliest Catch - 17.87%
42 Votes
Motor City Motors - 0.85%
2 Votes
Storm Chasers - 1.28%
3 Votes
Dirty Jobs - 17.45%
41 Votes
Man vs. Wild - 7.66%
18 Votes
Shark Week - 4.26%
10 Votes
Cash Cab - 1.70%
4 Votes
The Colony - 0.43%
1 Vote
MythBusters - 22.98%
54 Votes
Total Votes: 235
You may not vote on this poll.
Reply
Thread Tools Display Modes
Old 01-30-2010, 09:47 PM   #71
Member
Re: Headlight Restoration-new UV sealant idea
I am really interested in this thread as your headlight work looks awesome.
I tried the Meguires restoring system and it somewhat cleared the headlights, but I will need to do a wet sand job.
One friend told me to try One Grand Omega Glaze and a MF towel to clear head and tail lights, but I don't think that it would handle the heavy damage that the original pics showed.
I was told to stay away from the current headlight sealants and only consistently use a wax or plastic polish once the headlights were cleared. He said to use a QD to keep them up between waxing.
I hope you have the long term solution as I would love to take this challenge off my list of to dos.
Kurt_s is offline
Old 01-31-2010, 07:33 AM   #72
Member
dragster's Avatar
SEM products make a uv clear that comes in a rattle can that works well.
I am testing it out right know to see how it holds up. Will be adding this service in the spring if it works out.
dragster is online now
Old 02-28-2010, 09:32 PM   #73
sparkie's Avatar
Keep us updated....
__________________
sparkie is offline
Old 02-28-2010, 09:51 PM   #74
ArmstrongDetailing's Avatar
Quote:
Originally Posted by emaxxman View Post
What I would concerned with is the urethane yellowing. While they have some UV inhibitors, varnishes in general are very susceptible to yellowing from the sun.
I've been researching to find the best headlight sealant and one of the people I talked to pointed this out.
As he was giving me his sales pitch, he also pointed out that what he uses is permanent but is cured by UV exposure making it different than any other coating. He swears by it being superior to anything else. I have samples on the way and I will post up my thoughts after some testing.
When I say cured by UV rays, I mean it does not even harden at all until it is exposed to UV.
__________________
Troy Armstrong
www.armstrongdetailing.com
Follow Armstrong Detailing on >>>
ArmstrongDetailing is offline
Old 03-01-2010, 06:28 AM   #75
Nothing is permanent. UV rays destroy and degrade everything over time. It sounds like the salesman is pretty confident in his product. If it works let us know the process, the difficulty, and price. The urethane will fail, and the product you spoke of will eventually fail. Can it be sanded off if you make a mistake? The urethane can be sanded off once its cured, or if you goof up before its cured it can be wiped off with mineral spirits. One thing for sure is, the urethane is cheaper than any headlight coating. One can for $10 can treat hundreds of lights. If the coating you are trying does not cure until it is under UV rays sounds very similar to windshield repair resin. When I am making a windshield repair you keep it shaded until the repair is done, then the sun or UV light cures and hardens it. I am not saying the headlight coating is resin, but if it is, some resins yellow over time.
Also, I was told by an individual, that this spar urethane is exactly or an equivalent to what some light companies are using as "special coating". I cannot guarantee that rumor is true, but I figured it was worth mentioning.
HotRod is online now
Old 03-01-2010, 06:44 AM   #76
Quote:
I say permanent to differentiate it from a sealant that needs to be re-applied like a paint sealant.
As far as being sandable, yes it is but the good thing about it is you can wipe it off if you made a mistake as long as your not exposing it to UV it doesn't harden.
__________________
Troy Armstrong
Old 03-01-2010, 07:03 AM   #77
Ok, I see, it does sound like it would work well. Can you cure it with a UV light, or just direct sunlight? In windshield repair, we use small UV lights to cure the repair when sunlight is not available. If it works out, create a longevity thread for the sealant. Since it was made for lights, it probably will outlast the urethane. This thread is still ongoing with my longevity tests, and I think it will hit 9 months soon. It should last a year, and i have been told it will last over 2 years. I am not affiliated with any spar urethane companies, I am just learning this method and experimenting with it. It easily fits my current budget. For a product that was made just for wood, it seems to be working for plastic when mixed and applied correctly. If it turns out to be a dissappointment, I will then search for an alternative, so your opinions on your sealant is important.
Old 03-01-2010, 08:57 AM   #78
WindyCity's Avatar
Hey Hotrod my trial of the spar urethane has been holding up as well. One light is urethane and one light is a headlight sealer/sample from my supplier. They look the same and it had been 7-8 months now and they have been pounded with alot of winter road salt. Definitely lasted longer than Wolfgang headlight sealant kit that i used previously. Also I have not put anything over the urethane like wax or re coat the urethane or anything like that......
__________________
David Pilny
WindyCity is offline
Old 03-01-2010, 09:14 AM   #79
feslope's Avatar
What did you use for a uv source to cure it? How long did it take to cure? I have a couple of cans of the Sem Sealant and it looks to me like it requires a pretty high power source of UV. At $31.00 a can I really don't want to waste any of it.
feslope is online now
Old 03-01-2010, 05:35 PM   #80
Quote:
Thats awesome! Keep us updated. The urethane is pretty affordable compared to other UV sealers, It would be amazing if it lasts just as long as the pricey sealant, but I dont think that will happen.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Headlight Restoration Meghan How to Articles 17 01-27-2010 07:39 PM
3M Headlight Lens Restoration System DubinDE Product Reviews 10 06-26-2009 06:14 PM
Quick Review - 3M Headlight Lens Restoration System sr20det Product Reviews 5 05-25-2009 12:45 AM
Cobra headlight restoration matt@autogeek.net Show N' Shine 3 05-26-2008 07:45 PM
Headlight Restoration 01vw18t Auto Detailing University 6 12-21-2007 07:47 AM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
DP American Made Car Care Products
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
