Page 141 of 142 FirstFirst ... 4191131132133134135136137138139140141142 LastLast
Results 1,401 to 1,410 of 1420
  1. #1401
    Dec 2014
    Boonsboro, Md
    2,724
    Re: Headlight Restoration-new UV sealant idea
    Quote Originally Posted by Siwalsh06 View Post
    Hey guys i hope someone can answer me soon. I saw this post and decided to try it. My headlights were wet sanded and buffed n polished about r months ago didnt seal them with anything. Well they are already cloudy. So i found this post and gave it a try. I compounded and polsihed the headlights then applied the mixture. Came out great. Well this morning after the dew wore off the headlights they looked horrible. Really streaky. I dont understand why. What did i do wrong? During the day after i applied it the streaks disappered and the headlight looked great. Not its crap. I was able to rub it all off this morning with just a microfiber towel and some pressure. I mixed the stuff in those lil dixie cups. Idk if thts makes a difference. I read something about them on one of the pages. But can anyone help?
    Was the cup you mixed it in paper or plastic. The paper ones have a wax coating on them that may have been dissolved and mixed in with your product.
    Another thing if you are using the Spar method, do not compound or polish after sanding. The urethane needs some roughness to hold on to. It should fill the sanding scratches and leave them unnoticeable.
    ____________
  2. #1402
    Jan 2017
    Quote Originally Posted by Mantilgh View Post
    Yes it was a paper cup. I got plastic ones now. And so your saying just went sand it. Then wipe it down with either alcohol or the mineral spirits. Then apply the mixture? No need to buff compound on it? Or buff polish on it?
  3. #1403
    Dec 2014
    Boonsboro, Md
    2,724
    Yes, just sand.
    If you compound and/or polish the surface will be too smooth. It will be more likely to flake or peel off.
    ____________
  4. #1404
    Jan 2017
    Yes, just sand.
    Ah ok so thts why my headlights turned out like that then bc it had nothinf to grab to. Well since my headlights are already clean shoukd i just sand mine with like 2000? And then use rhe spar mix?
  5. #1405
    Super Member Rsurfer's Avatar
    Jan 2007
    14,094
    Be sure to wipe down with IPA before coating.
  6. #1406
    Jan 2017
    Yeah i do. I also heard yu can usr the mineral spirts to wipe it down to
  7. #1407
    Dec 2014
    Boonsboro, Md
    2,724
    I'm not a painter and I'm not totally positive on what grit would give you the best combination of adhesion and clarity. I'm pretty sure it's discussed somewhere in this thread.
    I think around 1000 would work well. Fine enough to be easily concealed, but rough enough to give it some bite.
    I use spar urethane on wood working projects and sand with either 220, or 400 grit between coats. I am using it straight though.
    ____________
  8. #1408
    Jan 2017
    Ill just drop down to a 1000, 1500, an 2000 on mine bc ima have to get tht stuff off now and then use the urethane
  9. #1409
    Jan 2017
    So i started with 800 just to get the old uv off. Then went to 1500 then 3000. Didntt have 2000. And i just did a quick pass on 3000. After that i wiped it down with IAP and then the spar mixture. It is clear for sure but im mot sure if its the scratches i can see or if its the lines from the uv. Headlight Restoration-new UV sealant idea-20170112_100454-jpgHeadlight Restoration-new UV sealant idea-20170112_100457-jpg
  10. #1410
    Aug 2010
    264
    I like the idea of the yacht varnish. Can you mix it 50/50 with mineral spirits?
    I just checked the U.S. price on Amazon, Wow! $65.00 a can. It has to be cheaper somewhere else.
  1. Replies: 9
  2. DP Headlight Restoration Kit vs Mothers NuLens Headlight Renewal
  3. Headlight Restoration-new UV sealant idea** Summary**
    By ShineTimeDetail in forum Show N' Shine
    Last Post: 06-08-2012, 09:47 AM
  4. Headlight restore application method idea
    By websdown in forum Auto Detailing 101
    Last Post: 02-03-2012, 02:19 PM
  5. Headlight Restoration
    By truckbutt in forum Auto Detailing 101
    Last Post: 08-21-2011, 08:57 PM
