08-21-2006, 05:38 PM
|  | 24 HR Queue | | Join Date: May 2006 Location: Blue Ridge GA (The Mtns.)
| | Quote: |
Originally Posted by articsilber323 justin my dads truck is all muddy inside the engine from having a little fun
what do you use 2 clean the engine out and what procautions should i take when cleaning out his for him
ty
-z | OK....
Spray the engine down first with a heavy degreaser. I use Purple Power from Advanced Auto. Let sit for about 5 minutes. Crank the vehicle and presure washe while it's running. Close hood and let run for another 10 minutes until dry. |
08-21-2006, 06:08 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Dallas, TX
| | | Great job as always Justin. Amazing turn around!
__________________ _____________________________________ 2003 Jaguar S-Type V8
2001 Nissan Quest SE
2000 Nissan Frontier XE
"Dogs in cars again. Going away. Going away fast" - P.D. Eastman, Go, Dog. Go! |
08-21-2006, 07:17 PM
|  | 24 HR Queue | | Join Date: Jul 2006 Location: Texas
| | | What did you use to get the wheel well so clean? I'm assuming the Karcher, but anything else? |
08-21-2006, 07:54 PM
| | Quote: |
Originally Posted by P1et What did you use to get the wheel well so clean? I'm assuming the Karcher, but anything else? | Good question! I would like to know that as well. Product(s) and technique please.
08-21-2006, 08:29 PM
|  | Senior Member | | Join Date: Aug 2006 Location: Gaffney SC
| | | Justin, nice job! Your fast, that would have taking me about 9 or 10 hours. |
08-21-2006, 10:07 PM
| | Quote: |
Originally Posted by P1et What did you use to get the wheel well so clean? I'm assuming the Karcher, but anything else? | Sprayed well with Purple Power and let sit for 5 minutes. Hit it with the Karcher very thoroughly (turbo nozzle). I came back with my left over NXT wash water and Meg's Versa Brush and scrubbed the inside. After it dried out, I coated it with Meg's Hyper Dressing 1:1.
I do this on EVERY vehicle. |
08-21-2006, 10:40 PM
| | Senior Member | | Join Date: Mar 2006 Location: New Jersey
| | Quote: |
Originally Posted by justin30513 Sprayed well with Purple Power and let sit for 5 minutes. Hit it with the Karcher very thoroughly (turbo nozzle). I came back with my left over NXT wash water and Meg's Versa Brush and scrubbed the inside. After it dried out, I coated it with Meg's Hyper Dressing 1:1.
I do this on EVERY vehicle. | Hyper Dressing is awesome black parts. After I rinsed my engine out, I gave a liberal spray of Hyper on the the whole engine compartment. It looked awesome the next day after it all dried. I may run the engine next time to speed up the drying.
Do you also run the engine and spray it with water if it's an aluminum engine? I heard that that was bad for alum engines...I guess cracking is a concern? |
08-22-2006, 06:36 AM
| | Quote: |
Originally Posted by emaxxman Hyper Dressing is awesome black parts. After I rinsed my engine out, I gave a liberal spray of Hyper on the the whole engine compartment. It looked awesome the next day after it all dried. I may run the engine next time to speed up the drying.
Do you also run the engine and spray it with water if it's an aluminum engine? I heard that that was bad for alum engines...I guess cracking is a concern? | I've had 12 Hondas (aluminum engines) and cleaned the motor sometimes 2 time a week. Never had a problem. Made sure to wrap up the distributor and wires though with a bag. Leaks on a HONDA. |
08-22-2006, 08:19 AM
|  | Moderator | | Join Date: Mar 2006 Location: Florida
| | Jason, you are the MAN!  Looks great! |
08-22-2006, 08:38 AM
| | Quote: |
Originally Posted by justin30513 I've had 12 Hondas (aluminum engines) and cleaned the motor sometimes 2 time a week. Never had a problem. Made sure to wrap up the distributor and wires though with a bag. Leaks on a HONDA. | Thanks Justin. I've got a 98 Accord and an 05 Ody. That's good to know about the distributor (for the Accord). |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
