| Re: So I should show what I did the past few days Yes, that is black wow on the trim and black plastic parts. Really good stuff, although you gotta let it dry a bit and re apply it, or at least rub it in a little more or it will look streaky. but a drop goes one hell of a long way.
As far as the roof goes, yes , I did every step up there. The center slats come off the rack making it very easy to get to most of it. I had to do a little hand rubbing directly under the frame, but the PC and pad can be shifted a little bit off center on the velcro mounting surface to get a little more reach and get just about the whole surface of the roof... |
