It was time to practice how to remove the orange peel effect from my car...
i am waiting for an order that contains 2500 and 3000 grit sand papers,6'' PFW and Meg's wool pad & diamond cut.So i used what i had at home and what i found in local market.
Meg's 1000 grit sand paper for wet sanding
3,5 '' PFW & Menzerna Power gloss compound on rotary
Menzerna RD 3.02 on orange LC 6''pad with rotary
Menzerna F106 FA on green LC 6''pad with rotary
Menzerna 85RD on black LC 5,5'' pad with UDM
i did only the hood and the right front fender.
So here are the pictures
The hood full wet sanded with Meg's 1000 grit sand paper
50/50 photos after the compounding/polishing steps
some pictures after the entire hood finished
and some pictures to compare the finished parts with the orange peel level of the rest parts
Then i took the car out the sun to check what i have done..i was disappointed and i have some questions...Those sanding marks need a wet sanding with less aggressive sand paper or they need more compounding with a bigger wool pad that i used??
Thanks for looking and all the advises are welcome....
