Go Back   Auto Geek Online Auto Detailing Forum > Auto Detailing Forums > Show N' Shine
Featured Photos
by admin
531 photos
7 comments
by admin
Autogeek's 1st annual Detail Fest
23 photos
10 comments
by admin
Exterior Gallery
45 photos
31 comments
by admin
531 photos
7 comments
» Autogeek Car Care Products
Reply
Thread Tools Display Modes
  #1
Old 06-06-2008, 01:21 PM
Dust2Glory's Avatar
D2G Detail: 1972 Pantera... 70+ pics
Well it definately was a pleasure to work on this car... I have never seen anything like it, nor knew of its existance. I was referred to this guy by a local auto paint shop and I am glad, over 5 trips to work on this car I made a little over $1000. Alot of hard work, sweat and putting up with this guys jokes:bla2:
I also want to mention that this guy got screwed over by a local paint shop, there were alot of scratches and wetsanding marks that were under the clear coat and were not going to come out. This customer is a top notch guy and didn't deserve to get messed over like this. So I made this paint as perfect as possible on top of the clear, but under is a whole other story:
Engine bay detail:
The care was up on jack stands as it lacked an engine and transmission. So first up was ONR wash with MF rags... the paint was ultra smooth all the way around, so no claying was done. Also, used a little engine degreased on the lower parts of the bay. After that the cust decided he wanted to wet sand the bay. So with 2000 grit 3m I went after it using ONR as a lube. After all was sanded I went after it with PG compound and yellow CCS pad and my flex, then followed up with SIP and orange ccs and then 106ff and white pad.
Then I washed again with ONR, used QD to help dry... for protection I knew something strong and durable was needed. So out came the DG 601/105 combo. Both applied by hand using TW foam applicators. So this is what you get.
Befores:
During paint correction:
After polishing and DG application:
More to come!!!
__________________
"When life hands you lemons, make faces at it!"
(my boy)
  #2
Old 06-06-2008, 01:23 PM
Dust2Glory's Avatar
Re: D2G Detail: 1972 Pantera... 70+ pics
Here are some pics I took of the whole car on the first day I saw it:
So the next time I went back it was to start working on the paint... again I did and ONR wash because the vehicle could not be moved. Again looking over the paint with my Brinkman I found more damage done to the paint that could not be touched becuaes of it being covered with clear coat!!
For the outside it was a combo of 2000 grit in some spots, especially in areas he touched up... using PG compound and yellow LC pads, SIP and orange pads then 106ff and white pads. On some parts of the car I got away with just SIP and 106ff.
__________________
(my boy)
  #3
Dust2Glory's Avatar
__________________
(my boy)
  #4
Old 06-06-2008, 01:25 PM
Dust2Glory's Avatar
The only process I did not take pics of was polishing out the trunk or deck lid or whatever you wanna call it, but it was more of the same method used on the rest of the car.
Now for the final day, the car was completely put back together engine and all, so I showed up extra early to give the car a good hand washing... not just an ONR, also to work on the wheels.
On the wheels and tires the were power washed off. On the rims I used Meg's Hot Rims Aluminum cleaner... let that dwell while I sprayed the tires and wells off with awesome apc. The hit the tires and wells with the black schmitt. When that was done I used a grout sponge and EZ brush to tackle the rims. then rinsed them off.
On the paint I used a 75/25 mix of NXT wash and Meg Hyper wash... and used a Schmitt grout sponge. I actually wash the vehicle twice to ensure I got every thing.
Rinsed off again and proceeded to spray the pantera down w/QD and dried with Blue Pearl drying towels from Autopia and Might I add these towels are AMAZING, better than my cobra WW!!!! Got the air compressor out and blew out all the cracks and crevices. And had the guy pull the car back inside.
Once inside I had my helper start on the interior and I re-polished the roof and two doors with 106ff and a white pad (while puting the car back together the guys rubbed against the doors and put tools of the roof:shead
The interior didn't require much... Meg's APC to clean, D2G interior dressing, ## leather cleaner + and ## leather conditioner. Used mix to clean carpets .
Now to crown jewel the paint. Started off using Lusso creme via flex and UDM and blue pads. buffed off using DD towels. Then applied Jetseal via red ccs pads. While it was setting we started polishing the wheels.
I have started using the Meg's Hot Rims Aluminum polish and have found it amazing stuff to work with, and it smells like cinnamon!!! Used foam applicator to buff, the QD the wheels to make sure all polish was removed... the applied Deep Finish sealant to the wheels via TW wheel applicator.
Once this process was done, Jetseal was removed using DD towels and I got to *RUB*:thumb: the car with RB Juiced Edition thanks to my good buddy Heath (Cooter)
Using TW foam applicators I didn't use WOWO motion or body lines, i applied more like when your polishing a car, side to side then back and forth... I don't know why, I just felt like it. Well I let that sit for 10 mins and I applied Meg's HD to the tires and Adams UC spray to the wells.
I again used DD towels to remove was and after about an hour I applied 4* Poly Charged Spray Wax, this stuff reminds me alot of AW, but I hope has alot better durability!!! Being poly charged and all or course. And then finally the windows using SIG and WW towels
The engine bay got a QD wipe down to boot.
__________________
(my boy)
  #5
Old 06-06-2008, 02:15 PM
Dust2Glory's Avatar
A few interior shots:
And some of my favorite shots:
Thanks for taking the time to look!!!
__________________
(my boy)
  #6
Old 06-06-2008, 02:42 PM
zoomzoom mazda5's Avatar
Great write-up and recovery work on the Pantera Dust!..........
__________________
ZOOM-ZOOM
  #7
Old 06-06-2008, 02:43 PM
cwcad's Avatar
No....thanks for taking the time to post! I loved the pictures!!
__________________
cwcad
Do What You Say....Say What You Do!!!
  #8
Old 06-06-2008, 03:33 PM
ehuth1's Avatar
Awesome work Michael. Looks like the engine was just installed in a freshly painted engine bay in that one pic!! Top Notch
__________________
A2D Photobucket
  #9
Old 06-06-2008, 08:42 PM
mingraygt's Avatar
Man that is some real nice work you did!
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
D2G Detail:1999 BMW M3 w/Fuzion LSP Heavy Pics Dust2Glory Show N' Shine 12 04-04-2008 09:26 AM
Detail Fest & Car Show Information Page Meghan Auto Detailing University 25 03-18-2008 07:20 AM
Dumptruck Concours Detail!! Pics!! trhland Show N' Shine 12 02-04-2008 01:53 AM
D2G Detail: 2006 Dodge Ram 2500 Lone Star Edition Dust2Glory Show N' Shine 6 01-15-2008 06:19 PM
Driven Auto Detail Truck & Trailer Pics (as you requested Justin!) mshu7 Auto Detailing Forum 22 10-29-2007 12:40 PM
» August 2008
2728293031 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
