It's a solid routine, that's for sure. If you don't want to use 3 different products to clean the wheels, tires and wells, you can just use the Eagle 1 product, it'll clean all of the above quite nicely. But if you have the time and products, go for it. I personally find it to be a hassle to carry 3 bottles and necessary brushes around to each tire, when one bottle will work
. I can't say that I've used Plastx with a PC before ... you may want to be careful with that. Once the polish goes clear, I'd stop the PC and wipe off with a towel to get optimal clarity.
