Video: Lake Country 1-Pad Polishing System
Show Car Garage How to VideosDiscuss Video: Lake Country 1-Pad Polishing System in the Detailer's Library forums; Video: Lake Country 1-Pad Polishing System
Lake Country has just introduced their brand new 1-Pad Polishing System, here'...
Form fitting pads are self-centering, simply align, press and buff!
Tri-density cushion backing plate maintains consistent cushion feel, won’t break down with use like conventional pads.
Full radius deign allows user to buff safely over entire pad surface as well as buff safely on edge.
1-Pad use 65% less material than most conventional buffing pads.
Pad shape allows easy transition from flat to vertical surfaces.
Action shots...
The backing plate is incredibly flexible while offering enough resistance to help maintain optimum contact between the working surface of the pad and the panel.
The full radius design enables you to safely buff with the face of the pad and the edges...
The self-centering feature helps to reduce the potential for swirls while provide smooth, balanced buffing...
A wide range of buffing pads available to tackle any project that comes your way...
Smooth buffing experience with CCS Technology...
Cupped design makes alignment a cinch and provide risk-free buffing around curves and tight areas...
Aggressive wool cutting pad for removing sanding marks after wetsanding or dampsanding as well as removing serious below surface paint defects.
Align, press onto backing plate and you're ready to buff!
Lake Country's 1-Pad Polishing System
I'll be doing some more testing with this new 1-Pad Polishing System from Lake Country, stay tuned for more information...
These pads and backing plate are very flexible, I watched Mike use them over the curves in Jason's truck and they just held nice and snug to the paint! Very cool job Lake Country!
When you say disposable, do you mean toss them after 1 use, or can they be cleaned?
Looking at how the backing is laminated onto these pads much like the Meg's SoftBuff 2.0 pads, I'd imagine these could be machine washed. Just a guess....
Hey Everyone. I dont want to get yelled at for spamming, but the video we did at our website is the latest version. We have been working on this for about 4 years and finally very happy with it. The backing plate will be in 3 colors with different densities.
