Results 11 to 20 of 21
    In time out
    Sep 2014
    Johannesburg,South Africa
    1,631
    Re: 5" backing plate on the lhr21 mark 2
    Does it run smoother with a pad on a panel without the washer mod vs. with washer mod? I found that made a difference with my G21. Just a thought.
    If we talking smoothness the 6" bp is considerably smoother and quieter with the 6" and you can see, hear and feel the machine is designed around the weight of the larger 6" bp.
    The washer makes absolutely no difference to the smoothness both on and off the paint what so ever but it sure as heck increases rotation considerably. It goes into hyper mode with the washer on.
    Apr 2012
    7,494
    Quote Originally Posted by Zubair View Post
    I wonder how much added stress with a washer mod running on it long term would put on the motor.
    2019 Nissan Rogue SL
  3. #13
    Super Member Todd@RUPES's Avatar
    Dec 2007
    Orlando/Oviedo
    409
    Quote Originally Posted by custmsprty View Post
    Zero.
  4. #14
    Super Member Marc08EX's Avatar
    May 2008
    4,108
    Quote Originally Posted by Todd@RUPES View Post
    Zero.
    Thanks for that info Todd!
  5. #15
    Sep 2014
    PA
    651
    Quote Originally Posted by Marc08EX View Post
    +1
  6. #16
    Apr 2015
    PGH, PA
    1,482
    Zero.
    From what I understand the washer mod gives more pad rotation while diminishing oscillation.
    I'm sure rhe machine will stall just as easy with the washer as with out..
    Does that mean a polisher with washer mod will correct less in the rcontour/concave areas ?
    As we know a pad that looses rotation but still oscillates still corrects..
    Or does the washer mod only effect oscillation at high speeds and doesn't effect lower speed aka stalled/oscillation only..?
  7. #17
    In time out
    Sep 2014
    1,631
    Quote Originally Posted by nothingface5384 View Post
    Oscillation/orbit does not decrease with rotation, on the contrary it increases. For every increase in rotation there should be an increase in oscillation.
  8. #18
    Super Member KBsToy's Avatar
    Jul 2011
    SW...Pa
    1,490
    I just a open box Rupes Mark 11 and used the spring washers I had on my DAS-15. You can just see light between pad and shroud. Will us polisher if it ever cools down here ....
  9. #19
    Dec 2007
    Orlando/Oviedo
    409
    On a random orbital tool, the oscillation is driven by the motor. The rotation is non-driven and is a function of multiple things such as friction applied to the pad, centrifugal force, and drag in the bearing. So modifying the tool by disengaging the anti-spin shroud is going to have the most dramatic effect on rotation when the tool is in free air. It may offer some benefit with smaller pad sizes on slower speeds, since the force imparted on the pad that causes rotation may not be dramatic enough to fully overrride the anti-spin shroud.
    When used with the recommended pad sizes and with the recommended speed settings (4-6 ES version / 3-4 Mark II) the net effect on polishing is very small, if any. Because the oscillation is driven by the motor, and the anti-spin shroud only limits rotation, there is no real change or effect on the former.
  10. #20
    Jan 2016
    Oklahoma City, OK
    Sorry for the ignorance....
    I just ordered my Rupes LHR 21 Mark II. What is the washer mod? Ive heard of it, but I don't know what it is.
    I'm very familiar with DA action on vehicles, but this is my first Rupes.
    How do I go about doing the washer mod, and what size washer do I need? Etc. I'm all about more rotation. I don't push down hard on my machines either... I try to let the machine do most/all of the work in the way it was intended. (without causing additional heat as well).
  1. Replies: 19
    Last Post: 05-31-2020, 02:42 AM
  2. 5 inch backing plate for the Rupes Mark II LHR21
    By RMarkJr in forum Ask your detailing questions!
    Last Post: 03-22-2017, 06:14 AM
  3. Mark Your Backing Plate - Makes it easy to see Pad Rotation
    Last Post: 04-30-2012, 10:37 AM
  4. Replies: 8
    Last Post: 10-25-2011, 07:47 PM
  5. Griots 6" backing plate VS. Lake Country's backing plate
    By ryanmcg1 in forum Product Reviews
    Last Post: 09-29-2011, 11:29 PM
