Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Like Tree10Likes
Thread: RUPES 2" Backing Plate not for use with the rotary connector and the RUPES Nano iBrid
  1. #21
    Senior Member Crispy's Avatar
    Jun 2013
    623
    Thumbs up Re: RUPES 2" Backing Plate not for use with the rotary connector and the RUPES Nano iBrid
    Well I finally got my polisher and I have to say I was wrong on the power issue as well as the "Big brother protecting me" issue. This baby spins at 2000-5000 RPM according to the spec sheet. You can imagine the heat generated by using a coarse Blue pad (they are very coarse) spinning on a small patch at 5000 RPM. To test I put my hand under a dry pad and let're rip. The bandages come off next week (just kidding).
    It got real hot real fast.
    I would not have tested this before hand had I not read this post, so kudos to Mike for starting it. I also use no more than speed 3 with the rotary tool with 1" pad, just to be sure don't "burn through" the paint.
    The small pad with the rotary tool is perfect for getting close to edges or on uneven surfaces. I used it on the underside of my trunk (great place to test products as the paint is "virgin", the original color and not visible if you make a boo boo.
  2. #22
    Jun 2009
    Stuart, Florida
    35,272
    Quote Originally Posted by Crispy View Post
    Just looking out for my forum buddies!
    As long as the tool maintains pad rotation under load you're good to go. High speed is not necessary as it creates a risk. Low speed plus time is the way to go.
    axel06 and k20trick like this.
    Host - Competition Ready on Velocity Channel
    IDA Board Member
    CD-SV, RT
    Competition Ready Facebook Page
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Click on a book to get your own copy.
  3. #23
    Apr 2015
    PGH, PA
    859
    Todd@Rupes
    Dylan@rupes , do you guys plan to make a rubber boot for
    the neck/head by chance?
  4. #24
    Senior Member medicscott's Avatar
    Mar 2015
    Long Island, New York
    582
    Learned this the hard way by the backing plate clamping down. It was difficult to remove. But I had a corvette with terrible scuffs on the plastic parts near the kickplate,so I jimmy rigged it so the 2" pad would freely spin on the plastic. After trying 3 other ways of getting the scuffs out, I went speed 4-5 with the Nano in rotary mode and bam. Cleaned the plastic down to perfection. I did do a test spot underneath the dash to make sure of no issues. Not really sure how I ever lived without this tool. It's simply amazing!
  5. #25
    Quote Originally Posted by nothingface5384 View Post
    Todd@Rupes
    Thats a great suggestion I could see the metal bumping into something by accident, but imo I think that metal part really blings out the polisher =)
  6. #26
    Junior Member nynewyawk's Avatar
    Jun 2016
    Glad I found this post. Got my iBrid last week and finally used it today. I attached the 2" plate to the rotary connector and after a few minutes the unit stopped working. Swapped batteries, even sued A/C adapter, still no go.
    Then off to the videos I went, trying to figure out ###. Found this video and all is well now, unit is bqack up and running. Would be nice if Rupes would provide and ACTUAL instruction manual, especially when we're paying $600.
    Once again Mike, thank you for some valuable information.
  7. #27
    Quote Originally Posted by nynewyawk View Post
    What did you do to get it working again? The Rupes manual shows not to use the 2" plate with the rotary fitting. At least mine came with instructions regarding that issue.
    Gotta love AutoGeek, seriously whenever I purchase products here I know that my chemicals are fresh, I tried purchasing elsewhere and it felt like the chemicals were old and sitting on shelves. For that reason I never make the same mistake again. Oh and if you get the gift certificates, you can use them to purchase the Rupes and buy them at bargain pricing.
  8. #28
    Jun 2016
    If you remove the plastic shroud around the head of the unit, you can then use the 2" plate in rotary mode.
  9. #29
    Feb 2015
    Ft. Lauderdale,Fl
    361
    Thanks for heads up! I probably would have cut or removed the shroud so the 2" would fit if I had not seen this post.
  10. #30
    Feb 2015
    Ft. Lauderdale,Fl
    361
    Todd@Rupes
    Yeah,X2 on this
  1. Rupes Ibrid Nano polisher is NOW here!
    By Delegance Detailing in forum RUPES BigFoot Oribital Polishers
    Last Post: 07-10-2016, 08:42 AM
  2. RUPES Nano iBrid Short Neck - What's in the Box?
    By Mike Phillips in forum RUPES BigFoot Oribital Polishers
    Last Post: 05-19-2016, 10:56 AM
  3. Rupes Bigfoot Nano (iBrid) is available for Pre-Order!!!
    By apthai in forum RUPES BigFoot Oribital Polishers
    Last Post: 05-04-2016, 10:16 PM
  4. Rupes Big Foot iBrid Nano
    By Vrtcl in forum RUPES BigFoot Oribital Polishers
    Last Post: 02-12-2016, 04:29 AM
  5. Rupes 15 vs Rupes 21 w/5" backing plate
    By expdetailing in forum RUPES BigFoot Oribital Polishers
    Last Post: 12-02-2014, 11:52 AM
» February 2017
293031 1 2 3 4
26 27 28 1234
