Results 11 to 20 of 30
Like Tree10Likes
Thread: RUPES 2" Backing Plate not for use with the rotary connector and the RUPES Nano iBrid
    Aug 2010
    New Jersey
    13,216
    Re: RUPES 2" Backing Plate not for use with the rotary connector and the RUPES Nano iBrid
    Quote Originally Posted by Dylan@RUPES View Post
    I find it always best to reference the metric measurement. Not only is it more precise, but its the unit of measure used in design and manufacturing as well, but I digress.
    The backing plate is just under 2" (50mm = 1.9685") which mates up exactly with the back of the pad (50mm) and flares out to 70mm at the face (a little over 2.75+")
    The smaller plate is 30mm with pads that are flared out to 40mm
    Metric is fine for me, I simply get confused because all (I think) of your pads have that pronounced taper which means the backing plate is a significantly different size than the business end of the pad. So I was just uncertain what the actual size of that larger pad was; that's interesting that it does approach the size of the Griot's Garage 3" pad.
    Thank you for clarifying that. What was the name of the gentleman from your company who was the Nano "handler" at Phil's?
    Senior Member mamut's Avatar
    May 2010
    195
    Jason?
  3. #13
    Aug 2010
    New Jersey
    13,216
    Quote Originally Posted by mamut View Post
    Jason?
    No, there was a 3rd gentleman from Rupes at that event, besides Jason and Dylan, who wasn't "famous" like them
    And no, it wasn't Todd, either.
  4. #14
    Senior Member The Guz's Avatar
    Jun 2013
    Lawndale, CA
    3,936
    Thanks Mike.
    I think you found yourself another book to write. A supplemental book on the nano to go along with the Rupes book.
    axel06 likes this.
    Competition Ready Team 1929 Bentley
    1999 Pontiac Grand Prix GT (Daily)
    2002 Chevy Camaro SS (Garage Queen)
  5. #15
    Senior Member axel06's Avatar
    Oct 2012
    vegas, somerset NJ,
    775
    and thats why ill be going back to the competition ready detailing class... cant wait to use this new ibrid thank you dylan and todd and mike
  6. #16
    Senior Member Crispy's Avatar
    Jun 2013
    652
    Well that just doesn't make sense. There is a speed dial and a trigger so why is "Rupes" protecting me from damaging my stuff. Only reason I can see is machine not strong enough for 2" in Rotorary mode (what a false).
  7. #17
    Senior Member Todd@RUPES's Avatar
    Dec 2007
    Orlando/Oviedo
    344
    Likely was Jermey Harding.
  8. #18
    Quote Originally Posted by Crispy View Post
    There are other factors to consider, but first you have to think in terms of scale. The inertia of that 70mm pad humming along in rotary mode is pretty high (in scale) - in rotary mode obviously you are in direct drive. Motor spins, pad spins; but it works both ways - pad spins, motor spins. Introduction of that much inertia (again in scale for the size of the tool) is going to carry the pad rotation beyond when the trigger is released - long term this is bad for the motor and all the linkage that goes to it. The direction of the thread can also be considered. The rotation coming to a stop could, with enough force from the pad, could begin to un-thread the adapter or the plate from the tool.
    There are a host of reasons you shouldn't run the 70mm pads in rotary these are some others to consider that also don't matter if you keep the pad in contact with the surface, but as a tool manufacturer you have to (unfortunately) also consider how people will MISuse things and protect against those scenarios as well. Afterall, everyone says they're a 'professional' but I'm sure we've all met plenty of 'professional detailers' that make us wonder how they even tie their shoes in the morning
    axel06 and Mike Moore like this.
  9. #19
    This is part of an insert that started being added to the Nano kits as well, to provide some guidance on what configurations were recommended. If anyone received and early production version of the tool and needs a copy of the pdf for their records please send me an email dylanv@rupesusa.com , I'll be happy to send it over.
    RUPES 2" Backing Plate not for use with the rotary connector and the RUPES Nano iBrid-nano_accessories_1sheeti-print-4.jpg
    axel06 likes this.
  10. #20
    Senior Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    817
    Good information. I'm still waiting on the second batch of long necks to reach our shores. This is one of the reasons I didn't buy the first batch. I wanted all the "gremlins" to be worked out. But I am ready to buy one now.
  1. Rupes Ibrid Nano polisher is NOW here!
    By Delegance Detailing in forum RUPES BigFoot Oribital Polishers
    Last Post: 07-10-2016, 08:42 AM
  2. RUPES Nano iBrid Short Neck - What's in the Box?
    By Mike Phillips in forum RUPES BigFoot Oribital Polishers
    Last Post: 05-19-2016, 10:56 AM
  3. Rupes Bigfoot Nano (iBrid) is available for Pre-Order!!!
    By apthai in forum RUPES BigFoot Oribital Polishers
    Last Post: 05-04-2016, 10:16 PM
  4. Rupes Big Foot iBrid Nano
    By Vrtcl in forum RUPES BigFoot Oribital Polishers
    Last Post: 02-12-2016, 04:29 AM
  5. Rupes 15 vs Rupes 21 w/5" backing plate
    By expdetailing in forum RUPES BigFoot Oribital Polishers
    Last Post: 12-02-2014, 11:52 AM
» March 2017
262728 1 2 3 4
