04-23-2013, 10:16 AM
#211
Re: Harbor Freight DA Polisher - New
Used the HF rotary this past weekend to correct a Bass boat after it was wet sanded. It worked great! It bogs down a bit but thats over come by bumping up the speed a bit. 2 passes with LC wool pads on the Megs Solo backing plate and it was a show room shine. Pics to come later
04-23-2013, 04:29 PM
#212
Thanks for all the reviews and insight. After reading everything it looks like it's not a bad purchase for being under 100 bucks.
04-24-2013, 01:45 PM
#213
I have a HF DA too that I got on Mother's Day. I think it was $59.99 and I had a 20% off coupon, so I paid $48 I believe. I bought a 5" backing plate so I can use 5.5" pads.
I would like to regrease mine as well, so if anyone knows where the directions are, post it please.
04-25-2013, 03:16 PM
#214
I have the directions from another thread, with pictures. I made into a Word file, but will try and get uploaded, this was not mine. I was able to do the process, which tool all of about 45 minutes.
1.) Remove the backing pad. Find the wrench that came with the unit and remove it.
2.) I was able to remove the (4) screws on the head with a good phillips head screw driver. Put some pressure on it so you don't strip the screws out, but can be done pretty easily.
3.) Pull the head off and clean out all of the OEM grease. I was able to just wipe out the a towel, then went back and cleaned with brake clean, to get it all out.
4.) Install new grease, I went to O'Riely's and bought their Red High Pressure Grease, about $5-$6, you will only use a little bit.
5.) Pack the head and grease the bearing on the shaft.
6.) Reassemble, wipe everything down and retorque the screws.
There is a bleeder hole on the back side of the head. Make sure you remove the red cap. Turn the unit on very slowly at first and you will purge some of the grease. Slowly work the speed up to operating speed. Do a final wipe down reinstall the red cover and your done.
I hope this helps. Others have removed all the pieces inside the head, but I did not see a need, just be careful when removing he screws and you will be good.
Let me know how it works out. Mine was much quieter afterwards, worth the little effort.
Bill
04-27-2013, 06:34 PM
#215
The bitterness of poor quality remains long after the sweetness of a low price is forgotten. Benjamin Franklin
04-28-2013, 11:17 AM
#216
Just repacked mine. Sounds better.
04-28-2013, 02:48 PM
#217
Here's a shot of what I just cleaned this weekend. This is on the HF DA, HF blue pad, and Ultimate Polish. The backing plate was changed to a LC 5.5". It fits the HF pads perfectly.
04-28-2013, 09:33 PM
#218
Repacked mine today as well. Made a difference. Like was said be carful with the screws.
04-29-2013, 07:24 PM
#219
Looks great, love the color.
04-30-2013, 12:49 AM
#220
Originally Posted by mavin
picked one up with 25% coupon, will let you know how it goes.
Mavin - Thanks for the coupon! I got $15.00 off on the polisher - only paid $44.95!
By SoreArms in forum Auto Detailing 101
Last Post: 05-28-2019, 08:53 PM
By DaneMcWilliams in forum Auto Detailing Tools and Accessories
Last Post: 08-14-2018, 03:27 PM
By yamaharider529 in forum Auto Detailing Tools and Accessories
Last Post: 09-29-2017, 02:27 AM
By Supergus1 in forum Ask your detailing questions!
Last Post: 12-04-2014, 08:04 PM
By jstevens66 in forum Auto Detailing Tools and Accessories
Last Post: 05-09-2014, 03:39 PM
