» Official Detail Fest 2010 Information Thread!! | |  | |
10-16-2006, 12:10 PM
#1 | | Member
| What Speed?
Im gonna use poor boys ssr1, and follow up with poorboys EX. Iam wondering what speed i should run the ssr1? and what speed i should run the EX? I will be using a white pad to apply the ssr1 and a blue pad to apply the EX, does that sound ok? this will be the first time to use the pc 7424, and i really need to know the proper speeds to run and any other tips on using the PC, thanks OH YEAH and how do i go around the trim or get the product right up to it w/o hitting the trim?
10-16-2006, 12:16 PM
#2 | | Senior Member
| I would run the ssr 1.0 at 5.5 and the EX-P at 3 or 4. For polishes you should run the PC at 5.5 as they will need a little heat to breakdown properly. For your glazes, waxes and sealants, they don't need heat, so just running it at 3 or 4 to spread it evenly is all you need. As for the trim, you can tape it if you want, but Poorboy's will not stain it so even if you hit it it won't hurt it. It's up to you. |
10-16-2006, 12:33 PM
#3 | | Member
iam not risking ruining anything , what could go wrong, so i can make sure it dosent, guess i just make sure that i keep moving the pc and not let it rest in one place
10-16-2006, 12:34 PM
#4 | | Member
and those pads will work good?
10-16-2006, 12:43 PM
#5 | | Senior Member
| Are you using the Edge system or the Lake country system?? You don't have to worry about burning the paint with the PC. The PC is a dual action polisher and meaning that it moves in two ways rather than in just one way like a circular polisher. This allows the heat to escape so there is no risk of burning the paint like you have with a rotary. That said, the polishes benefit from the heat produced by the friction when you run it at 5.5. It helps them breakdown, but it is not enough heat to damage your paint in anyway. |
10-16-2006, 12:53 PM
#6 | | Senior Member
is 5.5 a real speed? I thought there was just 5 or 6...
10-16-2006, 12:55 PM
#7 | | Senior Member
| hehehehehe Yes it's a real speed! I bump it up to 6 and then move the dial down just slightly to where the sound changes and that's how I find 5.5. |
10-16-2006, 01:04 PM
#8 | | Senior Member
The pc has a dial so you can set to 5.1 5.6 or what ever you would like.!
10-16-2006, 02:50 PM
#9 | | Senior Member
I don't know if some PC's are made different or what, mine has no inbetween. Sure it changes speed at about 5.5, but it's the same speed as 6. And from 5 to 5.5 it's the same speed.
__________________ |
10-16-2006, 02:57 PM
#10 | | Member
Join Date: Aug 2006 Location: Somewhere between heaven and Mexico
| Quote: |
Originally Posted by Grimm I don't know if some PC's are made different or what, mine has no inbetween. Sure it changes speed at about 5.5, but it's the same speed as 6. And from 5 to 5.5 it's the same speed. | Same here. Did we get the factory rejects with no 5.5 setting? |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » March 2010 | | S | M | T | W | T | F | S | | 28 |
| | 28 |
| 1 | 2 | 3 | » Car Care Brands | | | |
