car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
Go Back   Auto Geek Online Auto Detailing Forum > Buffers and Polishers > Questions about the Porter Cable 7424XP, 7424, 7336, Griot's and Meguiar's Dual Action Polishers
» Official Detail Fest 2010 Information Thread!!
» Current Poll
How do you prefer your information?
Paper Handbook - 24.77%
27 Votes
DVD - 11.93%
13 Votes
Digital PDF Download - 63.30%
69 Votes
Total Votes: 109
You may not vote on this poll.
Reply
Thread Tools Display Modes
Old 07-02-2009, 08:41 PM   #1
SpotlessDetail's Avatar
m105 problem?
Hey guys I'm currently working on removing swirls and a few scratches from my girlfriends black mustang. I'm using M105 with a green bad and M205 with a white pad with a PC. When I began the cars paint was rather hot but the sun went down so I thought it would be ok to begin compounding. I just cant seem to get any work time out of this stuff and its drying hard as a rock in about 30 seconds. What is the deal? My M205 is working fine and have no problems with the work time. This is the first time using this combo. Any info is appreciated. Thanks in advance!
__________________
Nothing is clean until its Spotless
SpotlessDetail is offline
Old 07-02-2009, 08:45 PM   #2
loudog2's Avatar
Re: m105 problem?
May need to let the paint cool more. Is the 205 removing the swirls? If so stick with that.
loudog2 is offline
Old 07-02-2009, 08:48 PM   #3
Tesla's Avatar
Re: m105 problem?
Are you using old M105 (rotary use only) or the new DA approved M105?
If it is the latter, are you priming the pad using the KBM?
Tesla is offline
Old 07-02-2009, 08:51 PM   #4
Re: m105 problem?
The 205 is removing all the swirls effortlessly but there are some scratches I would like to use the 105 for. I think it is a cooling issue as well. Just wanted to get some input from people who have used it before. What is the work time with these products? 2-3 mins? 2" per second? 3-4 passes like everything else?
__________________
Old 07-02-2009, 08:52 PM   #5
Re: m105 problem?
yes it is the new 105 and no prep on the pad. Never heard of it being a big deal. Different with 105?
__________________
Old 07-02-2009, 08:56 PM   #6
Tesla's Avatar
Re: m105 problem?
Quote:
I find if you don't prime the pad, M105 has a really short working time (older is especially short) but new version is longer.
Check this out, see if it helps... A look into Pad Priming - The Kevin Brown Method - Car Care Forums: Meguiar's Online
Tesla is offline
Old 07-02-2009, 09:00 PM   #7
Re: m105 problem?
this makes sense. Perhaps my pad is just soaking up most of the product right away leaving almost nothing to work with. Thanks I'll try it
__________________
Old 07-02-2009, 09:29 PM   #8
Re: m105 problem?
Had the same problem last weelend doing 93 vette when I start it was overcast 65 deg . The car was in rough shape had to use diamond cut first then 105 when I got to hood .I had blue skies no shade the hood temp was 146 deg on laser temp. I basically had do small area wipe with wet micro fiber, then with dry mf area by area . The 105 dries quicker in the heat reducing the work time greatly. The 205 is better I believe because it has more polish and a finer compound. Other than some fiberglass cracks the car came out great.
The Prodoct I Used
Megs Diamond Cut\Solo yellow Wool
Megs 105/orange
Megs 205/white
3m Ultrafina/Black
Megs 21 Syn Seal/blue/Indigo Bonnet for removal
And I Drank almost a Gallon of water ,It Took almost 6hrs cause the heat.
Steven C is offline
Old 07-03-2009, 02:39 PM   #9
Re: m105 problem?
I put the car under my canopy today and let it cool for a few hours. It was working much better plus I primed the pad so I think that helped out alot too. Thanks for all the replies! Mustang came out like new. Also didnt know that 105 could take out 2000 grit sand marks in one pass with a PC! That is some goooood stuff.
__________________
Old 07-03-2009, 05:36 PM   #10
Tesla's Avatar
Re: m105 problem?
The more I use it, the better results I seem to be getting. I'm almost getting my paint in LSP ready condition with just M105. Not quite but close.
Tesla is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
TSR Problem man_karat Wolfgang Car Care 4 04-20-2009 02:39 PM
M105/M205 results. would like opinions/comments BarryK Show N' Shine 20 03-26-2009 09:01 AM
Meg's #21 V 2.0 problem crash93ssei Auto Detailing 101 12 07-09-2008 12:49 PM
Wheel Cleaning Problem redvalkyrie Auto Detailing 101 12 04-19-2007 12:16 AM
I think I have a problem... supercharged Auto Detailing 101 13 12-15-2006 10:57 PM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
Griots Garage
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
