Quote:
Originally Posted by scottgt wowww...did it damage the paint |
No, its didn't. Lucky me that i didn't push much presure on the head of the udm. Its broken while moving on the paint, but before I used the edge blue, I just finished fist step on swirl mark removal with the edge orange pad & SSR2.5.
Yes, It hard to say that caused from the edge pad.(may or may not).
I just thinking of the iron axis is may not enought qaulity? (Just my thought it may not right)
I noticed that everytime when i use edge system the heat will effected to the edge adapter that can't tuchable but the plastic on the center look fine not burn on it...so the heat may cause the iron axis broken if you polish long run.
that what's i thought.
Just waiting for AG or David to respond on this case.
