Re: menzerna fg400 then one-step polish
Originally Posted by sansa
This is a great scheme to explain better what I mean with overlapping.
You can see the 3in1 covers the entire medium, finish and protection section while the sf4000 covers a little space in the finish section.
You can understand that basically if you use fg400+3in1 you're working twice to remove medium scratches (IMHO really more important than very light scratches to reach 10/10 gloss) and you are really sure you removed them
SF4000 has the ability to finish out whatever is left behind from FG400. SF4000 even has the ability to finish out holograms left behind from a rotary combined with a wool pad and SC300.
Originally Posted by FUNX650
I'd like to wrap this all up and neatly tie
a bow around it by saying, in a nutshell:
All of your concerns regarding which combination
of Menzerna's "correction fluids" to use for this, or
other detailing projects, can probably be resolved
by first performing the obligatory: "Test Spot".
Originally Posted by NextLevelDtail
You can do it but you are shorting your self of gloss, as 3in1 has more abrasives then sf4000, it will look good. But its not going to beat fg400 and sf4000.
However on some paints , (especially hard clears) 3in1 can look better then sf4000.
But 9 times out of 10 I'm going sf4000
You are the only one who said it isn't actually a stupid idea. I'd like you to explain which are the cases where you can see better results
PS. Pictures would be great if you can
Menzerna states 3in1 too has the power of removing holograms...
So talking about shc300 I'd use the 3in1 after that... Because from what I can see in the scheme even these two overlap each other...
Wouldn't it be a good combo? Shc300+3in1
Seems really few detailers here have tried the 3in1... Ok it's a relatively new product but we can't say fg400+sf4000 is the best without comparing it!
I haven't tried it too but and that's why I'm asking...
So examples and photos would be appreciated
Tell us why
Sansa, do you have any Menzerna products on hand to accomplish test spots to see what, where, and how it works?
Sorry that message was wrong
Read it above
Anyway like you all I have the fg400 and the sf4000 plus I have the pf2500
I'm considering to buy the 3in1. It depends on what you will suggest me :-)
PS. I could try the pf2500 with the fg400 to try to notice how many medium scratches it removes but I think it would be a difficult test if I compare it with sf4000
So what was the durability like?
I never tested the durability in this application. It was a performance based test in what its capabilities are.
By mats in forum Auto Detailing 101
Last Post: 10-07-2018, 03:30 AM
By wantboost in forum Auto Detailing 101
Last Post: 05-10-2017, 01:44 PM
By blackinnova in forum Products Guides
Last Post: 04-23-2017, 07:18 AM
By Kamakaz1961 in forum Products Guides
Last Post: 10-16-2016, 01:36 PM
By VarsityDetail in forum Products Guides
Last Post: 09-29-2010, 08:00 PM
