» Paypal Bill Me Later | |  | |
09-02-2012, 02:54 PM
#1 | | Optimum Product Support
| Application:Optimum Coatings
I'm using Opti-Guard in the video, but the instructions are the same. You should have a little more time and/or be able to have larger sections with Opti-Coat 2.0 than you'll see me using with OG, but in high temps/humidity OC can flash pretty fast too.
The car is a 2004 Viper with lots of curves and edges. I thought it'd be a good example to show both horizontal and vertical panel application.
My YouTube channel is ChrisAtOptimum and I'll be adding more videos as I have time. Feel free to offer suggestions if you see things that I need to cover differently. Application: Optimum Coatings.wmv - YouTube
__________________ |
09-02-2012, 03:05 PM
#2 | | Senior Member
| Re: Application:Optimum Coatings
Thanks for the vid Chris. How much OC/OG should be used on a mid size car? Quote:
Originally Posted by Chris@Optimum I'm using Opti-Guard in the video, but the instructions are the same. You should have a little more time and/or be able to have larger sections with Opti-Coat 2.0 than you'll see me using with OG, but in high temps/humidity OC can flash pretty fast too.
My YouTube channel is ChrisAtOptimum and I'll be adding more videos as I have time. Feel free to offer suggestions if you see things that I need to cover differently. Application: Optimum Coatings.wmv - YouTube | |
09-02-2012, 03:10 PM
#3 | | Senior Member
Great video Chris.....  ............Does this mean Nick won't be doing one?
__________________ BobbyG - 2004 Millennium Yellow Z06 Corvette |
09-02-2012, 03:21 PM
#4 | | Optimum Product Support
The viper is long with lots of nooks. I used approximately 6cc for all the painted surfaces. Less is used applying it directly to the paint vs. to the applicator, but even then 10cc should be plenty for a mid sized sedan. I would not advise going into an application trying to use as little as possible, though. Your goal should be even coverage regardless of how much you are using. I hope the video shows accurately the amount needed to coat a section. It doesn't take much, but it's a little hard to spread out from a central point or just from the applicator. A small trail across the section works best for me. My technique and applicator is always evolving, but what I show in the video is the easiest way I have found for teaching others. I plan on shooting supplement video that captures the flashing, when to wipe, and how to fix it when excess is allowed to dry. I couldn't capture that with this color in any light, so I'll have to try again.
09-02-2012, 03:23 PM
#5 | | Optimum Product Support
| Re: Application:Optimum Coatings Quote:
Originally Posted by BobbyG Great video Chris.....  ............Does this mean Nick won't be doing one?  | I would love to shoot a collaboration series for our line with Nick in that awesome "Showcar Garage!" Maybe I can show up a few days early for the next Detail Fest and we can get something going.
09-02-2012, 03:25 PM
#6 | | Senior Member
| Re: Application:Optimum Coatings  Fantastic video Chris!
__________________
#7 | | Senior Member
Originally Posted by Chris@Optimum The viper is long with lots of nooks. I used approximately 6cc for all the painted surfaces. Less is used applying it directly to the paint vs. to the applicator, but even then 10cc should be plenty for a mid sized sedan. I would not advise going into an application trying to use as little as possible, though. Your goal should be even coverage regardless of how much you are using. I hope the video shows accurately the amount needed to coat a section. It doesn't take much, but it's a little hard to spread out from a central point or just from the applicator. A small trail across the section works best for me. My technique and applicator is always evolving, but what I show in the video is the easiest way I have found for teaching others. I plan on shooting supplement video that captures the flashing, when to wipe, and how to fix it when excess is allowed to dry. I couldn't capture that with this color in any light, so I'll have to try again. | Good points, thanks.
09-02-2012, 03:44 PM
#8 | | Senior Member
Thanks for the video Chris!!
Looking forward to the rest of the series. NOTE:
I might have missed its introduction,
but glad to see that Optimum has: Opti-Erasure...
__________________ Be wary of the man who urges an action in which he himself incurs no risk~Joaquin de Setanti |
09-02-2012, 04:17 PM
#9 | | Senior Member
Bob | Link?
09-02-2012, 04:26 PM
#10 | | Senior Member
Originally Posted by Rsurfer Link? | It's seen, 'on screen', during the: products being used section...
at the 13-17 seconds mark of Chris' YouTube video he posted.
Bob NOTE: Opti- Eraser...not Erasure
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » June 2013 | | S | M | T | W | T | F | S | | 26 | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | » Car Care Brands | | | |
