Go Back   Auto Geek Online Auto Detailing Forum > Detailer's Library > Products Guides
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 08-04-2012, 04:12 PM   #11
Hammondc's Avatar
Re: help with sea foam
I would not use as intended (1/3 in each - gas tank, engine, oil) it until 100k miles. You just bought a very expensive fuel treatment. It is not going to hurt anything, I just do not think you will see any difference. Maybe put 1/3 in your oil via fill cap if you are changing your oil soon.
It does wonder on older vehicles though. I have had great results on a 2002 Jeep Wrangler, 2004 Mazda Protege 5, 1987 Ford Ranger and a Kodiak four wheeler that sat for 3 years without being run.
Hammondc is offline
Old 08-04-2012, 04:14 PM   #12
AeroCleanse's Avatar
I have been happier with Marvel Mystery Oil myself.
__________________
Platform Advocate for GTechniq
http://www.bespokecardetailing.com
AeroCleanse is offline
Old 08-04-2012, 05:10 PM   #13
For the gas tank its ok to put the whole can in. I have been doing that for years. It wont be easy as that to gain back power and up the fuel eco.
In my 2001 TL I use Amsoil PI in gas twice a year, changed the plugs to NGK Iridiums, and run Amosoil SSO 0w30 oil and have a cold air intake & headers. I gained about 2 to 4 mpg. On the hwy with 170k miles I still get 30mpg.
I am sure if I had the prices up for the mods and tradeoff for gas its probably net-net.
Bigbull2984 is offline
Old 08-04-2012, 05:33 PM   #14
Bill1234's Avatar
The car is a 2004 audi with a reccent oil change, and probabaly a very dirty engine as it has not been cleaned ever. It sounds loud and not right
__________________
Bill 1234
2004 audi a6 quattro
Bill1234 is online now
Old 08-04-2012, 06:24 PM   #15
Quote:
Marvel Mystery Oil, add 4oz per 10 gallons of fuel at each fill up. You can also add it to the oil.
__________________
Old 08-04-2012, 06:53 PM   #16
Put a can of sea foam in the gas tank every oil change. That is what I do to all 3 of my cars and it works great
phoenixs1234 is offline
Old 08-04-2012, 07:31 PM   #17
Bill1234's Avatar
Btw, the car in my avatar might be my fathers next, this will be mine when I finish my driving school
__________________
Bill 1234
Old 08-04-2012, 09:39 PM   #18
Member
Quote:
Originally Posted by rider9195 View Post
I used seafoam in my oil and vacuum line. My results, fouled spark plugs and now my car has a hesitation at 2100 RPM.
I noticed no difference in feel on my 55k mile car. Unless you don't change your oil regulary or your car has over 100k miles I wouldn't bother.
Also follow the instructions. It says something like x amount of seafoam to x amount of gas.
Quote:
Originally Posted by JAF06SE View Post
Yeah I wouldn't really bother with it if you're at low miles. Just get some Lucas fuel system treatment and pour it in. I too had an issue when I put it in my truck around 20k miles. Not sure if the seafoam caused it or if it just happened but it wasn't long after I did it.
Quote:
Originally Posted by DaveT435 View Post
Techron is supposed to be the best at cleaning deposits in the motor also in the cylinders where a lot of others don't clean. Just read the instructions and put the required amount in the tank with the appropriate amount of gasoline and your all set...
I'm with these guys
newbdetailer is offline
Old 08-04-2012, 09:47 PM   #19
Bill1234's Avatar
Im not going to put it in the oil, I just want to be sure that adding the whole can to a brand new tank of gas would be safe ?
__________________
Bill 1234
Old 08-04-2012, 09:53 PM   #20
david79z28's Avatar
Yes, I do it about twice a year in my truck. I add it to the tank at the gas station right before I fill up.
I never add it to the oil.
I only draw it into the intake on cars with some miles on them. I always change the plugs after doing so as well.
Good luck.
david79z28 is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
3™ Trizact™ Foam Discs 5000 FAQs Mike.Phillips@Autogeek Wet-Sanding, Cutting & Buffing 17 09-06-2012 10:10 AM
Foam Pad Selection Criteria TOGWT Auto Detailing University 2 03-25-2008 09:49 PM
Gotta admit, not too impressed with AG Foam Gun TCB Auto Detailing 101 24 07-11-2007 01:47 AM
Foam gun test: DP Extreme Foam vs. Megs NXT quantim0 Show N' Shine 12 12-18-2006 09:42 PM
Foamaster Foam Wash Gun Jason New Car Care Products 22 03-11-2006 07:31 AM
» May 2013
» Car Care Brands
DP American Made Car Care Products
