Need a heavy cut polish/compound. sugestions?
looking for a heavy cut polish/compound. i mostly stick with Wolfgang total swirl remover and really like the results i get but i need something that will takeout deeper swirls and defects. Been looking at the menzerna line alot of ppl seem to like the line. just wanted to see what everyone would suggest. thanks
Re: Need a heavy cut polish/compound. sugestions?
The biggest tool in the tool box is this combo:
Rotary
Wool Pad
Menz Power Gloss
You better know what you're doing playing with those 3 together.
i would say so. looking for something more with us of a DA for my guys to use. None of them have never used a rotary and im not always around.
Wolfgang TSR 3.0 is made by Menzerna
I would go with Menzerna Power Gloss which is very aggressive compound
Or Optimum Compound 2 which is a medium compound
Optimum Compound is an aggressive compound that finishes like a mild abrasive polish! Remove swirls and scratches with your polisher with Optimum
You can also using a more aggressive pad before moving to a compound.
Check out this Polish Comparison Chart out http://www.auto-geek.net/charts/wax-chart.pdf
Can't go wrong with either one.
I would go with Megs microfiber system. D300 follow up with your polish.
Cyan HT LC pads / Meg's 105
thanks for the chart toycar.
figure i'll give the power gloss a try an see how i like it.
Meguiars MF cutting disc with Meg M105
Power Gloss and HT Cyan pads. Finish without the need for a follow up polish. If I had tried the new opt cmpnd I would Dec recommend it as well. The original opt cmpnd requires a follow up polish IME. The Meg's mf cut will not remove heavy scratches that Menz PG will, and without proper technique will require follow up polishing.
M105 is a great compound. It doesn't have the most cut, but it does cut and it does it fast along with finishing well, period. It has a greater learning curve than some polishes, but once you figure it out you'll wonder how you ever detailed cars without it.
Enrique - Amateur Detailer Extraordinaire
"Man is an emotional animal, occasionally rational; and through his feelings he can be deceived to his heart's content." - Durant
By paulgyro in forum Auto Detailing 101
Last Post: 10-24-2019, 11:57 AM
By sushi in forum Auto Detailing 101
Last Post: 07-25-2012, 12:26 PM
By cobraa in forum Ask your detailing questions!
Last Post: 07-27-2010, 05:24 PM
By tommy in forum Auto Detailing 101
Last Post: 01-22-2008, 11:45 PM
By BlackRocks in forum Auto Detailing 101
Last Post: 06-01-2006, 01:21 PM
