Black Fire Waterless Wash Concentrate
Hello all,
Can the BFWWC be used as a rinseless wash? Has anyone used it as a rinseless? I've reached out to their product support specialists and wanted to get some feedback from the forum as well. Thanks
Re: Black Fire Waterless Wash Concentrate
Can it? More than likely yes; as a rinseless wash uses more water thus a waterless solution mixed like this should be safe.
But why not just buy a rinseless wash instead? Then you are sure you are getting the correct mix and results.
When mixing a waterless product Up as a rinseless I usually just mix it up the same as the rinseless product calls for.
Yes I tried to use BFWW as a rinseless wash.
I used it at 1:256 it worked OK.
Not as slick as some best rinseless wash out there, but the paint finish is good.
So I think it is acceptable for light dust, but not cars that normally ask for a rinseless.
Exotic Auto Detail trade review / feedback:
Think twice if you're going to trade with ExoticAutoDetai.
I ask ask because I just purchased a gallon of the BFWWC and was curious about using as rinseless sometimes. Thanks for your input!
Been there, done that. So no worries.
As noted above, it will work but I would say at maybe a slightly stronger than rinseless ratio to get it right.
What I have found most is that dedicated products usually work better than an all-in-one solution. But some of these waterless, rinseless, detail spray products are getting better and better.
Last Post: 05-13-2017, 09:32 AM
By cfiiman in forum Product Reviews
Last Post: 05-30-2015, 11:10 AM
By dennis hiip in forum Auto Detailing 101
Last Post: 05-16-2012, 07:54 PM
Last Post: 04-21-2012, 09:13 AM
By Emm in forum Products Guides
Last Post: 12-27-2010, 12:57 PM
