Brinkmann Dual Xenon Broke
The last couple of times I used my Brinkmann Dual Xenon it wasn't working right. I use it mostly as an all around flashlight in the garage, to see behind seats, etc... What was happening was, at first, the bright setting wouldn't work, then the lower setting worked but then only one of the lights would light. Expecting that if the batteries where dying that all settings would look dim, but work. So, I decided to take it apart, clean all the contacts, look for broken connections and loose wires. Here's what one looks like apart:
... Then, I ruffed up the battery connections with a file, bent out the prongs for tighter contact, stretched out the trigger spring, and coated all contacts with dialectric grease. Then, it hit me, maybe that's what happens when the batteries go bad on this thing (it's pretty new): the high setting stops working and then eventually only one bulb works on the low setting. So, I replaced all the batteries. Put it all back together and it's working perfectly. Only problem is, I'm not if I actually fixed something or if this is what happens when the batteries go bad. Anyone know?
High setting:
Low setting:
Thanks in advance!!!!
Thanks for your input. It's working good, for now that is. Also, I really like the size and ergonomics of it. However, I'm not sure if there was really anything wrong with or, or the batteries where dying. I hate when I find something in which I like how it works, but the durability of the product is poor (like Shark vacuums)
By bcgreen in forum Auto Detailing 101
Last Post: 09-21-2020, 03:57 PM
By Dal0522 in forum Auto Detailing Tools and Accessories
Last Post: 06-23-2016, 09:15 AM
By maximus20895 in forum Auto Detailing 101
Last Post: 05-12-2012, 08:17 PM
By walletless in forum Auto Detailing 101
Last Post: 04-09-2012, 07:12 PM
By veeko in forum Auto Detailing 101
Last Post: 09-29-2010, 04:04 PM
