Go Back   Auto Geek Online Auto Detailing Forum > Auto Detailing Forums > Product Reviews
» Autogeek Online Classes
Reply
Thread Tools Display Modes
Old 07-04-2011, 01:13 PM   #1
Director of Training
Mike.Phillips@Autogeek's Avatar
Grit Guard Pad Washer Cart
Love this cart!
You no longer have to bend over to clean you buffing pads!
By elevating the Grit Guard Pad Washer off the ground in a sturdy cart you no longer have to bend over to clean you buffing pads. The cart comes with 2 lockable wheels and if you lock them the cart stays in place as you run your polisher to clean the pads.
And of course the Grit Guard Pad Washer works great!
No camera flash shots...
With camera flash on... (same pad before and after shots)
You can see the compound residue building up around the inside top of the bucket via centrifugal force as you increase your RPM's to sling out excess cleaning solution and spent product.
If you machine buff cars for a living or often, you will love this cart and the pad washer...
Grit Guard Universal Detailing Cart
Mike.Phillips@Autogeek is online now
Old 07-04-2011, 05:44 PM   #2
Bunky's Avatar
Re: Grit Guard Pad Washer Cart
Does it come with some cover that allows you to remove the grit guard bucket and use it just as a cart?
I assume you can just put in a piece of wood to cover the opening.
__________________
Al
The Need to Bead
Bunky is offline
Old 07-04-2011, 06:47 PM   #3
SameGuy's Avatar
I saw it in the Bumblebee write-up and immediately searched for it in the store! I hadn't seen it before, and now here it is! Drool.
SameGuy is offline
Old 07-05-2011, 06:49 PM   #4
Didn't see any kind of cover, good idea though if you don't have a Pad Washer. We have two of these carts out in the training garage and the other one is going to be outfitted with the System 2000 Pad Washer just in time for our Advanced Class this Sunday....
Finally... no more bending over to clean a pad in a pad washer...
Old 07-05-2011, 07:18 PM   #5
Dr Oldz's Avatar
Looks a bit top heavy? I would hate to hit a crack or something on the floor and have everything dump over. Can you comment on this, Mike?
__________________
Jim
Dr Oldz is offline
Old 07-05-2011, 08:00 PM   #6
C. Charles Hahn's Avatar
The other cool part is this could be used with a shallower bucket (3 gallon or so) to house soapy water and sandpaper while hand sanding....
__________________
Charlie
Automotive Appearance Specialist - Serving Greater Lansing, Michigan
http://www.cchautoappearance.com/
C. Charles Hahn is offline
Old 07-05-2011, 08:21 PM   #7
Moderator
Meghan's Avatar
Very nice, I can't wait to try that out.
__________________
1-800-869-3011
meghan@autogeek.net
Meghan is online now
Old 07-06-2011, 02:45 AM   #8
oldmodman's Avatar
Now that is a product that should really save my back.
And I like the wet sanding idea too.
oldmodman is offline
Old 07-06-2011, 06:54 AM   #9
Quote:
It has large wheels, at least for this application and is actually very sturdy. I rolled it on and off the polishing deck multiple times and no problems with it being tippy. It would be the least of my concerns.
Quote:
I would still use a 5 gallon bucket, with 2 Grit Guard Inserts inside and about 4-gallons of water with a few drops of soap. This way there's plenty of water to swish a sandpaper around before removing it and wrapping a backing pad.
Doug Lamb told me about this idea about a year ago and I wanted one then... it's another great labor saving and back saving device from the Lamb boys...
Old 07-07-2011, 12:47 PM   #10
Moderator
Nick@Autogeek's Avatar
Excellent review Mike! I'm right there with you when I say work smart, not hard. The Grit Guard Universal Detailing Cart makes this possible with the ability to clean your pads using the Universal Pad Washer at a comfortable level.
It's often confusing for some people the first time they open up their Grit Guard Universal Pad Washer because the included extension insert is black, and not red like in the pictures on the product page.
As you can see in the picture below, the extension insert blends in with the Grit Guard because they're the same color. This can be confusing as they look to be one piece.
The extension insert removes easily so you can clearly see that it was included with your Pad Washer.
__________________
Nick@Autogeek is online now
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints Mike.Phillips@Autogeek How to Articles 44 05-07-2012 10:45 PM
Cleaning Pads with the Flex 3401 and the Grit Guard Universal Pad Washer Mike.Phillips@Autogeek How to Articles 26 05-04-2012 09:16 PM
Best Pad Prep For DA? kimandbrad21 Auto Detailing 101 9 10-07-2010 09:05 AM
Show Car Garage Video: How to use the Grit Guard Universal Pad Washer Mike.Phillips@Autogeek Show Car Garage How to Videos 8 10-05-2010 11:03 AM
The Edge Black 100% Domestic Wool Heavy Cut Pad Mike.Phillips@Autogeek Wool & Foam Buffing Pads 7 12-24-2009 09:46 AM
» May 2012
2930 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31 12
» Car Care Brands
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
