Re: Review: Duragloss 901 car wash and AquaWax
Originally Posted by Kurt_s
901 did a fine job of removing dirt from the paint surface which was just exposed to nearly a constant week of rain. I noticed that the small beads produced with Fuzion grew into larger beads after washing with the 901. I also noticed that the nuba glow associated with Fuzion diminished after washing with the 901, which I didn't expect after washing my wife's car (DGPS Sealant) with 901 the week before.
I dried the car with a Cobra Guzzler MF drying towel and used a mist sprayer to apply AquaWax as a drying aid. While the car looks shiny and clean, it no longer has the nuba glow that I associated with Fuzion, DGPS or OCW. It has a flatter, finish that looks both clean and shiny, with nice reflections of the sky.
A point of clarification: you used the Aqua Wax as a drying aid, correct? Was it after the car had been dried that you noticed that the nuba look had disappeared, right? If yes, then we do not know if the 901 contributed to this effect or not. I would expect the car to take on a sealant look after the application of a sealant, even if that sealant is only used as a drying aid. Does that sound right to everyone?
So to find out whether 901 diminishes the nuba look, you would need to dry the car without the use of a drying aid and then evaluate the paint. I don't know if you would want to test this, but it's something to consider the next time you wash the car after you have re-applied your Fuzion.
Personally, I don't really associate Fuzion with a carnauba look. I find Fuzion's initial look to be wet and glossy, but I don't recall it giving my car the glow that I have seen after applying Souveran or SV Smaragd or even Harly Wax. Fuzion reminds me more of Blackfire Wet Diamond than the other carnauba waxes I have used. But perhaps I need to look more closely. My eyes aren't very good, and I often don't see things that others see.
I had the same thought.
:dancebanana:
Sky's the Limit Car Care
Excellent review Kurt!
I probably wouldn't use AquaWax on a car that has a carnauba based LSP on it for fear of the very thing that you found: it reduced the carnauba look.
I washed my red vehicle yesterday. It has Fuzion on it. It went through a couple of days of rain (the beading is great!) so I had to wash with a hose (instead of ONR). I used Perl's shampoo which I have always been a huge fan of, but I thought perhaps the paint had lost some of it's carnauba look as well.
What do you normally use as a car wash soap with Fuzion?
I used a soft water hose rinse without a nozzle to flow water off the paint surface. The paint acted differently from before washing with 901 and after washing. Beads went from small beads to large drops after washing and before AQW.
I also didn't use AQW on the windshield, and the windows have a similar glaze or finish to the paint. I noticed that water ran off the windows differently after washing with 901 vs other car washes. The effect was quite pronounced and I noticed it both times that I used 901.
I also noticed a similar finish change with my wife's car a couple weeks ago, when I didn't use the AQW. I have WGDGPS on her bimmer. Like I mentioned in an earlier post, it kind of reminds me of a Mop & Glo finish or shell on a clean kitchen floor. Don't get me wrong, I'm not saying that it's bad, just different.
Fuzion has a reflective, 3D gloss with some light from within glow that I associate with a carnauba wax. To me, reflective images are not quite like as sharp edged mirrors, so there is a little "body" or richness to the curves of the vehicle. Fuzion is a hybrid wax, not a pure carnauba, and there are subtle differences between waxes anyway. Contrary to Fuzion prior to 901, there now seems to be shell over the finish.
AQW seems to have more of a muted, plastic look with less sparkle, if that makes sense. I get a sense that I have a layer of something over the finish. I would say that AQW is complimentary to 901 and overall a pretty cool combo, just maybe not the look that I'm after.
I wanted to get a feel for it versus OCW, so I'm glad that I had a chance to try it. Product synergy can be so important and what one person may love, another may hate.
Thanks Rob.
I've been using One Grand Blue 33, Megs Gold Class or ONR. The Megs seems more lubricating than Blue 33. Both seem to add a little more sparkle than 901. Blue 33 is the new wash developed for OGBW users and seems to compliment the carnauba-look leaning LSPs. Neither Megs or Blue stripped the Fuzion even after several months of car washes.
I'm still searching for the perfect car wash. I want it to clean without stripping the LSP, produces a safe lubricating wash solution, doesn't cost an arm and leg to use, and helps maintain the look of the LSP that I'm using. I need to pick up some Optimum car wash and I have sample of Sonax car wash to try too. I probably should give the WG car wash a shot too since I'm using their sealant and wax.
I have lots of options to try, one car wash at a time...
I've been fortunate to try several products recently provided by friends. Mark, thank you again for the 901 sample.
Today, I first washed my Artic White '99 BMW 528iT with Duragloss 901 then dried the car using AquaWax spray wax as a quick detailer drying agent.
I used ~3 oz of 901 with approximately 4 gallons of soft water. Yes, it has a cherry cough syrup smell to it. The mixture produced sufficient bubbles and a lubricated solution for use with my sheepskin wash mitt. I used a two bucket wash method with a grit guard for the painted surfaces.
The car was waxed with WG Fuzion this summer and still beaded well. I am a carnauba-look lover that appreciates more of a 3D, golden glow than a flater, shiny, defined edge finish. I find that look with WGDGPS, Fuzion, OCW and other carnauba waxes used over the years. I also like OID as a quick detailer that works well with DGPS, Fuzion and OCW.
I parked the car in a dirt parking space while my son attended a XC meet today. The car didn't appear to attract dust to the paint surface, so AQW seems to have some type of antistatic properties. I noticed a few more swirls in my paint after this car wash. I planned to polish out the paint and reseal with DGPS soon, but I was surprised.
I think that Duragloss 901 is a fine car wash and perhaps I should have used 4 oz of 901 instead of 3oz. Since I have more 901, I will increase the car wash concentration per gallon of water next time. At 3 oz, it didn't seem to have the same level of lubrication as Megs Gold Class, OG Blue 33, CG Citrus Wash and Gloss or ONR (when used as a no rinse). Both Gold Class and Blue 33 seem to add a little more glow and gloss to the paint and beading is different too (larger water beads with 901). I think that I prefer both Megs Gold Class and OG Blue 33 as a car wash. I want to try Optimum car wash as I am already a fan of ONR, OID, and OCW.
At this point, I prefer OCW as a spray wax to AquaWax as OCW leaves more of a golden, 3D glow to it. My white paint seems to pop more with OCW. Knowing that OID becomes more slick after 24 hours, I will update my comments regarding AQW tomorrow if my opinion changes.
In summary, 901 did a nice job of removing dirt from the paint. It left a clean surface with a shiny but flatter looking finish with good reflections, whereas my paint had a deeper glow to it before using the 901 and Aquawax combo. The car does not seem to attract dust, which is a great for keeping the car looking clean. I will give 901 a few more tries, but I prefer either OID as a drying aid or OCW as a spray wax to AquaWax.
Real nice review Kurt.. You would love DG AW if you lived in humidity. OCW and OID work great here on low humidity days. DG AW works much better here in SC.
Kurt try Ultima . Optimum WAS my favorite!
Thanks Jim.
Good point. SoCal doesn't have the humity issues so the users experience may differ by environment. Don't get me wrong, I admired my car today and the car still looks dust free.
Does Ultima have a spray wax?
Jim,
Did you mean Ultima car wash? I didn't think that Ultima had a spray wax.
Originally Posted by Dubbin1
Isn't it really a WOWA liquid sealant like OS?
By BadgerRivFan in forum Product Reviews
Last Post: 12-19-2015, 09:28 AM
By Flannigan in forum Product Reviews
Last Post: 03-13-2014, 09:37 AM
By CEE DOG in forum Product Reviews
Last Post: 08-13-2013, 10:37 AM
By IOMCAMARO in forum Product Reviews
Last Post: 04-22-2012, 08:05 PM
By FloridaNative in forum Auto Detailing 101
Last Post: 03-25-2007, 10:38 PM
25 | 26 | 27 | 28 | 29 |
