car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
Go Back   Auto Geek Online Auto Detailing Forum > Auto Detailing Forums > Product Reviews
» Official Detail Fest 2010 Information Thread!!
» Current Poll
What Discovery show do you watch most?
Overhaulin' - 25.78%
58 Votes
Deadliest Catch - 16.89%
38 Votes
Motor City Motors - 0.89%
2 Votes
Storm Chasers - 1.33%
3 Votes
Dirty Jobs - 17.33%
39 Votes
Man vs. Wild - 7.56%
17 Votes
Shark Week - 4.44%
10 Votes
Cash Cab - 1.33%
3 Votes
The Colony - 0.44%
1 Vote
MythBusters - 24.00%
54 Votes
Total Votes: 225
You may not vote on this poll.
Reply
Thread Tools Display Modes
Old 06-08-2009, 04:08 AM   #1
Member
Meguairs D170 Hyper Dressing
This review is for the D170 on exterior trim. I need to play with this product some more before I try using it on the interiors. Bare with me as some of the review covers the boring tune-up.
I had high hopes of doing an all purpose service on my wife's Infiniti FX35: changing the oil & air filter, rotating the tires, washing, claying and finally using my new Flex to fix some major water spots and swirl marks.
I started with a wash, did a half dry job, since I planned on claying. When I pulled it into the garage and got the front end lifted I remembered the dreaded belly pan that is held in place by 12 bolts. I'm not sure if the belly pan is for aero dynamics, noise control, or off roading/snow, but it's a serious PITA to get off. I drained the oil and while I was waiting for the dripping to finish I went after the air filter. The air filter is buried among hard plastic pipes and elbows. You have to loosen several bolts, and one hose clamp to get at the filter box. Since I had most of this stuff loose I decided to pull out all this plastic and give it a proper rub down. I sprayed it with some APC+, agitated it with a fender soft bristle brush, and rinsed with my pressure washer. What a great job the APC+ does on killing all the fine dust that lives inside the air intake pipes, and all the grease and road grime that's caked on the outside! As a dressing I sprayed some D170, let is sit for a few minutes and as I reassembled I would wipe with a cotton towel. It looked great! I reinstalled the belly pan and cleaned up and went inside for dinner. Sorry, I didn't think to take pictures of the nice clean engine detail, or the belly pan.
After pizza I came back out I had lost all my motivation for detailing. I was even too lazy to rotate the tires. But since the car was up on jacks I figured it was a good time to detail all the black plastic that makes up the bottom of the bumpers, and the bottom of the side skirts. Luckily this product is thin enough to be soaked up by a sponge and is water soluble. The stuff I was working with was diluted 3:1. I used the scrubby side of a kitchen sponge and scrubbed/coated all of the plastic trim, including opening the doors to get access to the toe kicks. Then I went around and used a towel to wipe all the excess off. For the wheel wells I gave 3 or 4 mists into the finders to give a light coat to all the plastic and suspension bits.
For the tires I sprayed it directly onto the tires and used a tire scrub brush to work it in. I didn't get the tires totally clean to start with, since I had planned on detailing the wheels individually as I took them off. I let the solution soak into the tire as I wiped the wheels down with D155 Last Touch Detailer. I used a cotton cloth to wipe the excess off the tires.
Verdict (Review in Summary)
D170 works great on hard plastic and soft rubber door gaskets. It works great on engine bits. It's light enough to become a fine mist for misting the underside of fenders with out dripping or running. On tires you need to start with clean tires, then you might need two coats to finish the job.
Here's some progress pics of the tires:
Tires before, messy wheels, dirty tires.
After being sprayed and scrubbed. I think I used a little too much, but no big deal.-
After single wipe down with cotton towel.-
after wheel was quick detailed and tire wiped down once more. Notice wheel well and plastic fender trim looks great, not too shiny or too matte.-
When I get some time this week I'll do a write up on cleaning/waxing this beast. I'll report on how the D170 holds up after a wash.
santov is offline
Old 06-08-2009, 08:26 AM   #2
mrGolfRider's Avatar
Re: Meguairs D170 Hyper Dressing
interested to know how shiny it is after a couple of days, right now for me, that is just to much shine...
__________________
Matt Ferguson
Needed Touch Detailing
Making the city shine, one car at a time.
mrGolfRider is offline
Old 06-08-2009, 08:19 PM   #3
Hyperdressing is great, does not last to long by itself in my opinion. I love it on engines though
sal329 is offline
Old 06-08-2009, 08:20 PM   #4
Quote:
It can be diluted 1:1 to 4:1 depending on how shiney you like it to be
sal329 is offline
Old 08-29-2009, 01:41 PM   #5
PolishedWorks
Kris R's Avatar
so what CAN you put on tires that wont just come off on a few days? I mean when you first buy tires they stay pretty well lubed up and shiny for a few months, then they get dry and its an endless battle of applying everything under the sun. I have quit using Megs Hot shine and Black magic because they just dry out the rubber and leave your tires brown....
So what CAN you use that isnt silicone based (bad for tires) and will last more than a few days?
__________________
http://www.polishedworks.com
Kris R is offline
Old 08-29-2009, 02:55 PM   #6
GMC83's Avatar
Well, there are good and bad types of silicone. Not sure if the Hot Shine caused your tires to turn brown, sounds like blooming to me.
Meguiars Silicone free dressing?
GMC83 is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Silicone or Water Based Tire Dressing: What's better and Why? Dust2Glory Auto Detailing 101 26 05-13-2008 02:47 AM
Meg's Hyper Dressing HAN Auto Detailing University 1 11-30-2007 07:05 AM
Anyone want to split a gallon of Megs Hyper Dressing? FMINUS Auto Detailing 101 1 08-05-2007 12:23 AM
Meg's Hyper Dressing Question CalgaryDetail Auto Detailing 101 3 06-01-2007 05:40 AM
Meg's Hyper Dressing Padron Auto Detailing 101 5 10-15-2006 01:07 PM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
Wolfgang Concours-Series Car Care
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
