Review: Nick's Rinseless Wash Beta
I received my sample from Nick this past monday. It was -20F outside so I decided to wait until today when it was close to 40F. When the product arrived, it was frozen solid. Not a surprise considering a squirt of water from a bottle will freeze in midair at those temps. After letting it thaw, there was no separation or anything to indicate there would be a problem using it.
For starters, I love the fragrance. I couldn't place it; my wife thinks it's blue raspberry jello. But I do like to use rinseless washes for light interior duty, so having a pleasant frangrance is a must. the second thing of note is the dilution ratio, and specifically for waterless wash: 1:128, that's insane. That's ~7.5ml in my 32 oz bottle. This dilutes down further than most anything in my arsenal of rinseless options.
So I lined up a few different rinseless washes. Uber was not among them as I currently only have a rinseless dilution left. Each were diluted as a waterless and rinseless wash, then the hybrid rinseless wash was used (prespray with waterless, then perform rinseless). The prodcuts were diluted as follows:
For Rinseless: D114 1:128, ONR 1:256, Ech2o 1:200, UWW+ 1:384; Beta 1:256
For waterless: D114 1:32, ONR 1:64, Ech2o 1:25, UWW+ 1:44, Beta 1:128
Here's the line up
I then agitated each bucket just a bit to see if we get any suds
D114
UWW+
ONR
Ech2o
Beta
Next I surveyed the condition of the vehicle. Quite a bit of salt spray, road film and grime. The vehicle is wearing a non-AG coating and has a silica spray sealant on it and possibly some ech2o left as well.
Each product was used on either a door or rear quarter to test. As previously noted, panels were initially presprayed with waterless wash (until slight runoff occured, then a rinseless wash was done using 530 gsm towels.
The only product that had any grabbiness was ONR. The rest were able to glide over the paint, some better than others. All were able to suitably clean the vehicle with no discernible wash induced marring. Beta did provide some unique features. The lays flat on thee panel rather than beading like ONR, UWW & Ech20. This is important feature to me as it ensures the entire panel is wetted. D114 is the only other product that does this. It also wipes off very easily and clean. The only place I found any discernable residue was on a small section of the roof. ONR left some residue. UWW and ech20 did as well, but they have some intended protection that is expected to require a little additional buffing. D114 left no residue.
Some after picks of the car
The car look pretty good, but the wheels are still filthy, so I set out to use the waterless wash only to clean them.
Initial condition
After spraying, the pic is bad, but you can see than Beta started to shift the dirt and brake dust immediately
This took a bit more effort to clean, but still not grabby at all. I'm not expecting a perfect wheel with a quick wipe down, but it did an admirable job.
Finally, I can't leave the glass and trim in a state of filth. Beta work just fine on the trim, nothing of note to report. The waterless dilution also worked great on the glass leaving it streak free. Being able to use a single product at 2 dilutions to do the entire exterior is an advantage to these products.
Being able to use it for rinseless, waterless, clay lube and paint prep is very appealing. I also use the paint prep and waterless dilutions for light interior duty and will need to play around with that more as well, but at the waterless dilution, it did great on my dash and seats.
I'd consider a couple minor tweaks to bring this product over the top. The color at dilution is almost non-existent. When I'm working, I like to be able to identify a product by color quickly so when I walk over to the shelf or cart, I know which bottle to grab 3 steps before i get there. There are other ways I can do this, like a different bottle or sprayer, but I plan to have this in a garden sprayer and I only like 1 style of those. I wouldn't mind if the fragrance was a bit stronger. I like something that smells good if I do interiors with it, but likewise, I don't want anything too strong that makes it obvious a detailer has been there, my goal is always to have an interior appear new, not detailed. Having this in a similar proportioning bottle to uber rinseless would be perfect; the amount of product used is so small that I would be saving an old UWW bottle if I don't get one from Beta.
I have a few more things to play with (like clay lube), but initial indications are that this is a winner.
Re: Review: Nick's Rinseless Wash Beta
Very nice product review...
Thanks for the easy to follow text
and its accompanying pictorial.
____________________________________
Here's a couple of things that
also caught my attention:
For waterless: D114 1:32; ONR 1:64, Ech2o 1:25, UWW+ 1:44, Beta 1:128
•IMO:
-1:128 is not such an out-of-bounds
WW dilution ratio. That's the same
ratio that I dilute D114 for use as a
WW...not the 1:32 ratio you have
listed above.
•For me:
-D114 @1:32 is reserved for
use as a "panel-wipe".
I actually like the fragrance strength as it is. I can actually do a whole wash with this stuff in an enclosed garage without getting sick.
•IMO:
listed above.
•For me:
I will respectfully disagree, but only to a point. The container specifies 1:128 dilution as a rinseless.
I do realize Mr. Stoops has provided alternative dilutions, but I do not think it would be reasonable or fair when testing a number of products to deviate from the official dilution. With that in mind, it would also be highly questionable for me to say both the rinseless and waterless dilutions are 1:128.
As far as the 1:32 for waterless; I believe that was one of the numbers thrown out right when it was released, though I can't recall where I got it.
I have been using as a panel wipe at 1:10. Again, I think this was stated right when it was released.
Regardless...
-Meguiar's/Mr. Stoops' official dilution ratios
for Meguiar's D114 were published plenty
of times...on many different MOL threads.
- 1:32 was never, ever listed as the official
dilution ration for D114 as a WW.
- 1:32? That's for "panel-wipe" duties.
I also need to provide some additional info.
I previously state that Beta lays flat on the paint. This was the case for a filthy car. When using it again today on the same car (relatively clean), it did bead.
This seems to indicate that ONR, UWW and ech2o have constituents that actively promote beading. d114 has constituents that actively promote wetting. Beta seems to have neither. And I would like to see something that actively promotes a wetted surface.
By Cruzscarwash in forum Product Reviews
Last Post: 02-07-2017, 11:21 PM
By Kevin845 in forum Auto Detailing 101
Last Post: 12-27-2016, 07:53 PM
By andy0902 in forum Product Reviews
Last Post: 12-19-2016, 07:12 PM
By Sizzle Chest in forum Product Reviews
Last Post: 12-19-2016, 03:42 PM
