If I do get this coating off my car. I am gonna try different products on different panels. That will do the trick haha.
Even with all the high spots in indirect light, its doing its job magnificently.Its user error and environment for me.I know I would have had stellar results if that was not the case.
People always stare and admire the paint. They don't know what to look for. I see it daily and know that the spots/smudges are there lol
Question for you, if I read your original post correctly it almost sounds like you let the Fuzion dry and haze after applying it, is that correct?
2019 Nissan Rogue SL
No I did not. As soon I finished spreading the wax to a panel I wiped of right away in small circular motions.
This is why I felt it was weird when wiping off. The towel felt grabby - almost like wiping off hazed 845.
Originally Posted by emmjaygti
Wipe off was weird too, the towel felt a little grabby when wiping off in circular motions, taking little bites. But once wiped off it felt nice and slick. I only applied to one panel before wiping off. Roof was applied half panel and then wiped off, before moving to the other side.
That's interesting. I've used Fuzion countless times and never experienced that. But I've always used it on top of WG 3.0 or as a stand alone. Never on top of a coating.
