Go Back   Auto Geek Online Auto Detailing Forum > Buffers and Polishers > Porter Cable 7424XP Updates
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 04-15-2012, 07:58 PM   #1
Porter Cable 7424XP Smoking
Anybody have a similar experience with the porter cable smoking after a little use.
I am using a 5 inch backing plate with lake county 6.5 foam pads.
pnewman3402 is offline
Old 04-15-2012, 08:03 PM   #2
Tundra_10's Avatar
Re: Porter Cable 7424XP Smoking
I never had a burning smell or even a "new smell" when using mine. I would suggest talking to whoever you bought the unit from and try to get a replacement if it was a recent purchase, otherwise consult PC if its within warranty still.
__________________
Why was the Energizer Bunny arrested?... He was charged with battery.
Tundra_10 is offline
Old 04-15-2012, 09:23 PM   #3
umi000's Avatar
Where is the smoke coming from? Also, you really want to be using a 6" backing plate for 6.5" pads, as the smaller backing plate will "cut" into the larger pads, possible causing the pad to fail; additionally, more support (from a larger backing plate) means more cut, ceteris paribus.
__________________
Francis
umi000 is offline
Old 04-20-2012, 01:33 AM   #4
opie_7afe
Posts: n/a
read this thread it might be whats wrong The Compression Washer
and umi offered some sound advice, go with 5.5" pads with the 5" backing plate, the smoking could be because of the difference in size, i know in some of AG's pics they show a 5"bp with 6.5" pads. 5.5" pads offer better correctional/polishing ability vs the 6.5" pads they maintain rotation better rotation is what gives you defect removal along with the oscillating motion(the jiggling) heres another good read as well. How to MAXIMIZE your DA Polisher good luck hope this helps
Old 04-21-2012, 06:36 PM   #5
The compression washer was the cause everything works perfect. I got great customer support at the auto geek location in Stuart FL.
Old 09-24-2012, 09:56 AM   #6
Member
TomG's Avatar
Quote:
Could you explain, were you using the washer and they told you not to, or the other way around? I have tried it both ways, I get more power without the washer but there doesnt seem to be enough clearance for the backing plate. I have been using the washer but I feel like it really hurts the power.
__________________
"If it ain't a stick, it ain't a Wrangler."
TomG is offline
Old 09-24-2012, 10:48 AM   #7
swanicyouth's Avatar
Smoking on the job? At least it wasn't drinking.
swanicyouth is online now
Old 12-03-2012, 11:44 AM   #8
Yesterday, I polished my car with my PC7424xp with a LC White 5.5 CCS foam pad, mostly on speed 6 with very slight downward pressure (enough to compress the pad slightly, but not enough to slow the rotation). While I didn't notice any smoking from the PC, I did notice a good amount of steam coming off the pad. The pad felt warm to the touch, but not hot. Also, my car's paint was warm, but not hot to the touch after I'd make a section pass. I took the foam pad off and also noticed steam coming from the backing plate. It was unseasonable warm in Central IL yesterday -- 60ish degrees.
I wonder how much of a concern this should be?
And yes, my compression washer is installed properly
eatnosenuggets is offline
Old 12-03-2012, 12:16 PM   #9
Johny B's Avatar
Quote:
good one!
Johny B is offline
Old 12-03-2012, 12:25 PM   #10
CWallace's Avatar
sounds like a reason to buy a flex 3401!!!!
CWallace is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
How to clean your foam pad on the fly Mike.Phillips@Autogeek How to Articles 75 05-01-2013 11:05 AM
The Definitive How-To Article for Removing Swirls, Scratches and Water Spots Using a Porter Cable 7424XP, G110v2 or Griot's Garage Polisher Mike.Phillips@Autogeek Tricks, Tips and Techniques 47 09-19-2012 09:13 AM
Grocery Cart Scratch Removal using Pinnacle Advanced Swirl Remover and Porter Cable 7424XP Mike.Phillips@Autogeek Pinnacle Wax 2 09-27-2009 12:23 PM
New At Autogeek Porter Cable 7424XP Dual Action Polisher Meghan Porter Cable 7424XP Updates 19 06-22-2009 07:18 AM
New At Autogeek Porter Cable 7424XP Dual Action Polisher Meghan New Car Care Products 9 06-18-2009 07:48 AM
» May 2013
» Car Care Brands
Autogeek.net - We are car care
