Go Back   Auto Geek Online Auto Detailing Forum > Buffers and Polishers > Porter Cable 7424XP Updates
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 08-04-2011, 08:24 PM   #1
PC + Surbuf + Meguiars
Hi All,
I have been trying to get the swirls out of my car for quite some time. I think my main problem, is that I have so much gosh darn wax on the car, that whenever I use a polish or swirl remover (i usually use adams) the swirls go away to some extent but come back. Heres what I did
Washed the car with my foam gun
dryed
used some wax/tar remover on a microfiber towel
Surbuf + M105
Surbuf + M205
I noticed that the M205 leaves a haze that I have to use alot of pressure on my microfiber to get out. I have a feeling Im doing this wrong..can someone help?
Thanks
jeffs42885 is offline
Old 08-04-2011, 08:28 PM   #2
rider9195's Avatar
Re: PC + Surbuf + Meguiars
Surbuf and M105 is pretty aggressive. Have you tried something less aggressive? M105 w/ Orange Pad. Surbuf pads do not finish down well. Use a foam polishing pad with M205 to refine the finish after the M105.
__________________
Ryan 2006 Volvo S60 R
rider9195 is online now
Old 08-04-2011, 08:33 PM   #3
Surbuf + M105
Surbuf + M205
do you have any foam or microfiber da pads to try after surbuf 105? Surbuf+205 is going to give you a haze more than likely, even though I have never tried 205 w/ a surbuf.
Fast Eddie is offline
Old 08-04-2011, 10:11 PM   #4
SpoiledMan's Avatar
I've had no luck finishing with surbuf pads. Cutting/compounding yes. Break out some foam for the finish.
__________________
Black cars are easy!
SpoiledMan is offline
Old 08-04-2011, 10:22 PM   #5
Setec Astronomy's Avatar
SpoiledMan??? Dude, I didn't know you came to this neck of the woods! Say hello to Patrick for me and tell him I'm sorry what happened at WCDS...hopefully I helped him clean up a little.
Setec Astronomy is offline
Old 08-04-2011, 10:34 PM   #6
SpoiledMan's Avatar
PM me and bring me up to speed cause I'm totally lost.
__________________
Old 08-04-2011, 11:00 PM   #7
onlycodered's Avatar
Have you used a claybar at all? I didn't see that in your steps and it wouldn't be a good idea to polish without claying first.
__________________
onlycodered is offline
Old 08-05-2011, 08:23 AM   #8
RaskyR1's Avatar
On softer paints M105/Surbuf can leave a hazed mess, which can usually benefit from a median step. On harder clears you can usually go right to your finishing polish (M205), but as others have said you need to use a foam polishing or finishing pad. Surbuf are not meant for final finishing. The swirls you see coming back are likely micro marring from the Surbuf pad and the oil in M205 were simply masking them until you wash it.
__________________
Quote:
Originally Posted by CieraSL View Post
http://Raskysautodetailing.com/
RaskyR1 is offline
Old 08-08-2011, 05:38 PM   #9
Hi all,
Yes I did clay. As far as the finishing pads- I do have a white adams pad that I can use with the 205. Will post the results.
I also bought some 4'' pads/backing plate..surbuf/lc to get along my spoiler and in smaller spots.
Old 08-08-2011, 06:05 PM   #10
BobbyG's Avatar
Washing with a solution of Dawn, all purpose cleaner, and warm water should remove a majority of sealants and wax. Claying next will remove whats left so any left over surface protection should net factor into this.
I don't have any experience with Surbuf pads however lets ask a few questions and see if we can help move this along.
Closeup photos showing the surface defects would help allot.
Meguiar's M105 and M205 are staples of the detailing world are the baseline which many products are compared.
These are some of the basic questions I would ask that might help get to the root of the problem.
  • Did you prime the pad enough so the compound is working between the pad and paint and not being absorbed into the pad?
  • Is your polishing speed set between 5 and 6?
  • Are you working a 2' X 2' section
  • Is the downward pressure sufficient enough to allow the pad to rotate and correct the finish?
  • Are you performing 4 to 6 complete passes per section?
  • Are you moving the polisher to fast, not allowing it enough time to work?
There are many things that could be coming into play here but not seeing it or being there makes it difficult to diagnose and resolve.
__________________
BobbyG is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
what is with all these abbreviations??? SpotlessDetail Auto Detailing 101 73 04-16-2013 02:32 AM
New Product Abbreviation Chart sparkie Auto Detailing University 26 04-01-2013 08:09 AM
Can we get Abbreviation Chart Please!!! B&B Tennessee Off-Topic 43 06-16-2012 07:10 AM
so confused why165 Auto Detailing 101 27 01-24-2011 04:29 PM
A request!! dinkydow Auto Detailing 101 32 07-08-2006 03:38 PM
» May 2013
» Car Care Brands
