Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Nov 2010
    Northern CT
    208
    Backing plate for sanding with the 7424
    For those of you sanding with a 7424, what are you using for a backing plate? I'm assuming that your using the regular adhesive 6" Discs? Any info is appreciated! Thanks.
    May 2011
    307
    Re: Backing plate for sanding with the 7424
    meguiars back plate plus interface pad plus sanding disks
    Senior Member C. Charles Hahn's Avatar
    Aug 2007
    Lansing, MI
    3,105
    Meguiar's 6" Unigrit System (shown here with 1500 grit sanding discs):
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    http://www.cchautoappearance.com/
    Nov 2010
    Northern CT
    208
    Thanks, I'm looking for something a little more versatile so I could have more paper choices. I'm not looking for finishing discs actually. I've got the sand and prep the bed of my truck so I need to run 400 grit so I was hoping for like a plain smooth rubber backing plate.
    Aug 2007
    Lansing, MI
    3,105
    Quote Originally Posted by goathead View Post
    Head up to Home Depot or Lowe's, then... they should have what you need.
    Charlie
    Nov 2010
    Northern CT
    208
    Yeah, I checked HD and they didn't have any backing plates...of course it's possibly the lamest HD I've ever been to. I'll check Sears too, just didn't know if anyone used it for other than finish/damp sanding.
    Senior Member gewb's Avatar
    Oct 2008
    Denver, Colorado
    562
    Porter Cable has a "wood worker" version of the 7424 (which came out decades before the one you have). The backing plate should be interchangable.
    HOWEVER - pay attention here - you also need to get and change out the counter balance as the one for sanding is smaller (less weight) than the one for polishing vehicles.
    Regards,
    GEWB
    Linux Reg. User #206357 (Feb. '99)
    "Can't get there from here."
    Jun 2009
    Stuart, Florida
    35,009
    In my article list under Wetsanding - Colorsanding - Dampsanding there's a number of articles on this topic, here's one...
    Meguiar's 6" Unigrit Sanding and Finishing Discs
    Meguiar's new Unigrit Sanding Discs are specifically designed for damp-sanding and can be used with a 5/16" orbit sander. These Unigrit discs offer uniform particle size and placement over the face of the disc and are available in both 3" and 6" sizes.
    Meguiar's 6" Unigrit Sanding and Foam Finishing Discs
    Meguiars Unigrit™ 1500 6 Inch Sanding Discs - #S61500
    Product Attributes
    • Precise, uniform grit particles for a smooth and even sanding pattern
    • Ideal for removal of dirt, orange peel and severe paint defects on fresh finishes
    • Sanding = No foam backing
    • Quickly levels texture
    • Micro hook & loop interface
    Meguiars Unigrit™ 1500 6 inch Finishing Discs - #S6F1500
    Product Attributes
    • Precise, uniform grit particles for a smooth and even sanding pattern that buffs out in seconds
    • Finishing = specialized foam backing
    • Quickly refines sanding marks & removes moderate surface defects
    • Soft foam backed disc for texture matching and scratch refinement
    • Always used damp – water only
    • No sanding lube
    Meguiars Unigrit™ 3000 6 Inch Finishing Discs #S6F3000
    Product Attributes
    • No sanding lube
    Meguiar's 6" Sanding Backing Plate - #S6BP
    Back side
    Working face side
    Product Attributes
    • Distributes pressure for smoother sanding/finishing
    • Precisely tuned outer edge for ideal disc contouring over flat and curved surfaces
    • Allows quick disc changes with micro hook & loop interface
    • 5/16 thread for use with air or electric DA’s
    Meguiar's 6" Foam Interface Pad - #S6FI
    Back side
    Working face side
    Approximately 1/2" thick
    Product Attributes
    • Safely follows contours and works closer to most edges
    • Ideally engineered for use with Unigrit Sanding & Finishing Discs
    • For use with air or electric DA’s
    • Results in one grade shift upward in finish results
    Intended Markets
    Sanding Discs vs Finishing Discs
    Sanding Discs --> Body shops
    S61500 -> S6F3000 --> Machine Compounding
    The S61500 6 inch Unigrit 1500 Sanding Discs are primarily for leveling surface texture like Orange Peel or for removing heavy surface defects like dirt in paint on fresh paint. Removes material quickly but with good control leaving behind a sanding mark pattern that is quickly and easily refined to a higher level using the S6F3000 Finishing Disc. #3000 Finishing marks are then removed using a rotary buffer.
    Finishing Discs --> Detail Industry
    S6F1500 --> S6F3000 --> Machine Compounding
    The S6F1500 and S6F3000 6 inch Unigrit Finishing Discs are more targeted at for use by Professional Detailers to remove moderate to fine defects. These foam backed discs removes material quickly but with excellent control over the depth of the sanding mark left behind. The S6F1500 sanding marks are easily refined to a higher level or removed with a rotary buffer. The S6F3000 are easily removed with a rotary buffer and a cutting compound.
    Air-Powered DA Sanders
    These discs can be used with Air-powered DA Sanders like the 3M Orbital Sander.
    3M Orbital Sander or D.A. Sander
    Meguiar's G110v2
    The also fit the Meguiar's G110v2 but note there are no electric sanders approved for working around water.
    The backing plate attaches to the Free Floating Spindle Assembly
    If you choose to use the interface pad, the "M" logo attaches to the face of the backing plate. The "M" side of the Interface pad has the "loop" material while the face of the backing plate has the "hook" material.
    The loop backing on the back of the sanding disc attaches to the hooks on the face of either the interface pad or the backing plate.
    The 6" sanding discs can also be used by hand using the Meguiar's Hand Pad - S-6HP
    Host - Competition Ready on Velocity Channel
    IDA Board Member
    CD-SV, RT
    Competition Ready Facebook Page
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Click on a book to get your own copy.
  10. #10
    Jun 2009
    Stuart, Florida
    35,009
    Quote Originally Posted by gewb View Post
    Regards,
    GEWB
    Gary's right, at least that's the original idea behind the different weights of couterweights... for what it's worth, I've never checked or changed a counterweight on a tool before using it to dampsand or machine compound, polish or wax paint.
    Neither the Meguiar's or the Griot's DA Polishers have the ability to modify counterweights and we use these in all our Wetsanding Classes to dampsand.
    I'm not saying my way is the right way or the best way just saying all the sanding, cutting, polishing and waxing seems to get done with any of these tools and with whatever counterweight is on the PC that's closest to my hand when I reach for one.
    The origins of the Porter Cable are documented in this thread...
    The Free Floating Spindle Bearing Assembly - The Story Behind The Story...
    IDA Board Member
    CD-SV, RT
    Twitter
    Instagram
  1. Recommend Pads and backing plate for 7424(non-XP)
    By jem7sk in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 12-30-2014, 12:06 PM
  2. 7424 Backing Plate Question
    By swanicyouth in forum Auto Detailing 101
    Last Post: 06-20-2012, 02:43 PM
  3. 3 inch Backing Plate & PC 7424
    By gatoman39 in forum Ask Mike Phillips your detailing questions!
    Last Post: 04-30-2011, 12:13 AM
  4. New backing plate and pads for 7424?
    By jmy2469 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 09-16-2009, 09:43 AM
  5. What is the biggest backing plate I can use for my 7424
    By david walton in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 03-04-2007, 09:52 PM
» January 2017
1 2 3 4 5 6 7
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30 31 1234
