Results 1 to 6 of 6
    Apr 2006
    121
    What is the best for beginner?
    I read alot of reviews and threads and tried Griots garage and found majority of these buffers size, make are very similar. My question is what is the main advantage of 1 over the other? Example what is the advantage of Griot's 6" buffer compared to Porter, Flex? It appears as far as starters with a buffer foam pads (according to Griots) don't burn the paint.
    Dec 2010
    610
    Re: What is the best for beginner?
    Probably and impossible question to answer because it will be personal opinion. What's the difference? The Griot's and PC are DA's with an unforced rotation. They will stop spinning if you apply too much pressure or you hold them at an angle. The Griot's has a bit more power and the PC is a higher build quality. The Flex has a forced rotation so it will not stop spinning regardless of pressure or angle of attack. The Griot's and PC are cheaper than the Flex. Small 4" pads are available for the DA's but not the Flex. Now, pick your poison based on what you need and like.
    Senior Member Pockets@PoorboysWorld's Avatar
    Jul 2009
    West Nyack, NY
    835
    From my personal experience I didn't like the Griots machine I like the porter cable better and the Flex just blows them both out of the water........ Pretty much with the Griots, PC, and the Flex the only way you can damage your paint is if you throw the machine at the car lol. If you have the funds do the Flex for sure!! You won't be sorry you did and it does more correction work than them combined. I know some detailers that went from using a rotary to using the flex just becasue of ease of use so you will not "grow out" of the Flex like you will very quickly with the Griots or the PC.
    Chris (a.k.a. Pockets)
    Warehouse Manager
    Pockets@poorboysworld.com
    (845)215-9700
    Senior Member S2K's Avatar
    Jul 2010
    990
    Dave
    Black is not a color, it's a part time job!
    Senior Member CEE DOG's Avatar
    Jul 2009
    Florida
    7,358
    Quote Originally Posted by Pockets @Poorboy'sWorld View Post
    :dancebanana:
    Sky's the Limit Car Care
    Senior Member ScottB's Avatar
    Mar 2006
    South Florida
    18,802
    There are so many variables including price and budget. I might suggest considering a Random Orbital Buffer, 5.5 Hydro tech pads, and a 5 inch backing plate. Add some great polishes like Wolfgang, Menzerna, or Megs.
    Scott
  1. beginner here
    By jcb19983 in forum How to make money detailing cars
    Last Post: 08-12-2012, 03:52 PM
  2. Beginner need help!
    By Jmoran in forum Auto Detailing 101
    Last Post: 06-09-2012, 11:12 PM
  3. Replies: 4
    Last Post: 05-19-2011, 06:48 PM
  4. Beginner
    By glat1000 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 10-14-2010, 01:54 AM
  5. A beginner needs some help!
    By P1et in forum Auto Detailing 101
    Last Post: 08-11-2006, 06:46 PM
» January 2017
1 2 3 4 5 6 7
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30 31 1234
